Thread: what happens when your idle air control valve is bad?
Results 1 to 6 of 6
  1. #1 what happens when your idle air control valve is bad?
    columbus
    My car has been running rough and I think it could be an idle air control valve is bad. I have a 1994 grand prix GTP, so if it is bad what are some significant indications that it is bad?
  2. #2 Re: what happens when your idle air control valve is bad?
    Donating Users mystic231's Avatar
    Michigan
    If the IAC is bad it won't usually start since the throttle plate is closed completely and the IAC is shut there's no air getting into the engine. When this happens you can normally get the motor started by holding the gas pedal down a bit to open the throttle plate
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  3. #3 Re: what happens when your idle air control valve is bad?
    columbus
    I get it to start by giving it gas, but it only does this when its cold. any ideas what else it could be?
  4. #4 Re: what happens when your idle air control valve is bad?
    IL
    its a possibility that your throttle body is loaded with cooked carbon and that it so happens to clog up the IAC and prevent it from moving, and/or the IAC decided that its time to retire (correct me if I'm wrong)...
  5. #5 Re: what happens when your idle air control valve is bad?
    I'm in agreement with cleaning the TB. It's a good starting point and will ensure the IAC can move freely if it's gunked up.
  6. #6 Re: what happens when your idle air control valve is bad?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    just replace the iac valve..problem solved
  1. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  2. Evaporator Control Valve
    By 00Kevin in forum General Tech Discussion
    Last Post: 05-31-2010, 10:34 PM
  3. A/C compressor control valve location?
    By PCweber in forum General Tech Discussion
    Last Post: 08-11-2009, 08:25 PM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. P0508 Idle Control System Circuit Low on 2000 pontiac grand prix
    By Bigkamp22 in forum General Tech Discussion
    Last Post: 07-17-2009, 12:29 PM
