what should i do next to my car its an 04 gtp with k&n intake and cat back exhaust
thatwould be nice but i use this as a daily driver and family car so i was just lookin for bolt on upgrades
Bio i would assume it would be 4 grand right....his title says "help me spend 4 grand"
Also what Bio said...what are you goals for the car?
turbo is bolt on.
You dont have to crack a single gasket on the motor.
even though you should.
the LIM and VC gaskets are probably leaking/going to leak in the next couple years.
And to answer: Searching Forums Query: maf upgrade
No, unless you're outflowing your stock one, theres no point. You're not going to gain anything.
Some run the feed lines off the oil pressure sensor.
and?
when you're done you put a plug in it.
I'm thinking take two GXP's and weld the second engine in the rear of the first car.
600 HP and two V8's.........
Built tranny, and with the 1 or 2k or so youll have left, cam, pulley, headers, tune.
i was thinking heads, cam, headers, injectors, pulley swap, throttle body,intercooler and a tune hows that too start
You would need a new transmission with all that most likely.
the cam kinda dictates what heads you'll wanna get.
with that setup, you'll be going fast. unless it's just an xp or vs or s1x cam. but if you're getting heads, get a bigger cam. high flow cat maybe? like bio said, what are your goals? 4k will get you a lot and you'll still have money for a TEP trans
