Thread: helpme spend 4 grand
Results 1 to 19 of 19
  1. #1 helpme spend 4 grand
    california
    what should i do next to my car its an 04 gtp with k&n intake and cat back exhaust
  2. #2 Re: helpme spend 4 grand
    Donating Users BoostnBlackGTP's Avatar
    Waterloo, Iowa
    turbo
  3. #3 Re: helpme spend 4 grand
    california
    thatwould be nice but i use this as a daily driver and family car so i was just lookin for bolt on upgrades
  4. #4 Re: helpme spend 4 grand
  5. #5 Re: helpme spend 4 grand
    Never Never Land
    Bio i would assume it would be 4 grand right....his title says "help me spend 4 grand"
    Also what Bio said...what are you goals for the car?
  6. #6 Re: helpme spend 4 grand
    Pennsylvania
    Headers
    Injectors
    Cam
    Intercooler
    STBs
    Rear trailing arms
    Morimoto projector retrofit
    Gauges
  7. #7 Re: helpme spend 4 grand
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    Quote Originally Posted by 90cobraclone View Post
    lol thats awesome! so you just wanna put your family in a LITTLE danger. dont wanna go all out or anything... lol
    dont worry man, im in the same boat
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  8. #8 Re: helpme spend 4 grand
    turbo is bolt on.
    You dont have to crack a single gasket on the motor.
    even though you should.
    the LIM and VC gaskets are probably leaking/going to leak in the next couple years.
    And to answer: Searching Forums Query: maf upgrade
    No, unless you're outflowing your stock one, theres no point. You're not going to gain anything.
  9. #9 Re: helpme spend 4 grand
    Never Never Land
    matt wouldnt you have to remove the oil pan to weld in fittings for oil feeds?
  10. #10 Re: helpme spend 4 grand
    4k?? Id be thinking cam E85 Tune and TRANSMISSION!!!
  11. #11 Re: helpme spend 4 grand
    Charles City, IA
    Some run the feed lines off the oil pressure sensor.
    SMGPFC Two Nipple General
  12. #12 Re: helpme spend 4 grand
    and?
    when you're done you put a plug in it.
    I'm thinking take two GXP's and weld the second engine in the rear of the first car.
    600 HP and two V8's.........
  13. #13 Re: helpme spend 4 grand
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    wheels+tires, airbags or lower, buy a second engine and begin building
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  14. #14 Re: helpme spend 4 grand
    Grand Island, Nebraska
    Built tranny, and with the 1 or 2k or so youll have left, cam, pulley, headers, tune.
  15. #15 Re: helpme spend 4 grand
    Never Never Land
    Quote Originally Posted by TheOtherNick View Post
    I had no idea you can do that....i might do that if i go turbo with the camaro.
  16. #16 Re: helpme spend 4 grand
    x2 thats where I'd put 4k
    Like I posted earlier hes got a 04 already so it should have a Gen5 Id do cam headers E85 tune and Transmission.
  17. #17 Re: helpme spend 4 grand
    california
    i was thinking heads, cam, headers, injectors, pulley swap, throttle body,intercooler and a tune hows that too start
  18. #18 Re: helpme spend 4 grand
    You would need a new transmission with all that most likely.
  19. #19 Re: helpme spend 4 grand
    Troy OH
    the cam kinda dictates what heads you'll wanna get.
    with that setup, you'll be going fast. unless it's just an xp or vs or s1x cam. but if you're getting heads, get a bigger cam. high flow cat maybe? like bio said, what are your goals? 4k will get you a lot and you'll still have money for a TEP trans
  1. how much should i spend?
    By savannaz34 in forum Off Topic Discussion
    Last Post: 08-22-2010, 10:02 PM
  2. 300 bucks to spend what to buy?
    By killakross5o4 in forum Off Topic Discussion
    Last Post: 02-16-2010, 07:20 AM
  3. $750 to spend what are the must do mods??
    By Enjoijoe in forum General Tech Discussion
    Last Post: 06-23-2009, 01:36 AM
  4. I've got $800 to spend on my GP GT...
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-18-2008, 04:04 PM
