Thread: Effects of Case Relearn
Results 1 to 16 of 16
  1. #1 Effects of Case Relearn
    KSteelwheelzJ klj5022's Avatar
    New Carrollton,MD
    Hey how much does a case relearn help you get full potential of tune? since i have to get one. Like what might i be missing without it?
    I just wish the police loved my car as much as i do 3.5,160 Stat,HAI,ZZP F/R STB, SSAC Headers, Reptile PCM
  2. #2 Re: Effects of Case Relearn
    New Carrollton,MD
  3. #3 Re: Effects of Case Relearn
    your pcm wont detect misfires properly?
  4. #4 Re: Effects of Case Relearn
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    i dont believe it does anything...you dont have to do a case learn when you drop a new motor in your car that the computer hasnt seen before so why would you have to do one with a newly tuned pcm on the original motor? if that was the case wouldnt you need a relearn after every new sensor you put in?
  5. #5 Re: Effects of Case Relearn
    A CASE relearn is an advanced way for the car to detect misfires, based on the relationship of the cam position sensor to crankshaft position sensor. Anytime you permanently intend to install a PCM that did not come directly out of your car, you need a CASE relearn
  6. #6 Re: Effects of Case Relearn
    or touch the chain.
  7. #7 Re: Effects of Case Relearn
    Feb 2010
    somewhere cold
    how do you then do a case relearn with hptuners?
  8. #8 Re: Effects of Case Relearn
    Its in there somewhere?
  9. #9 Re: Effects of Case Relearn
    Feb 2010
    somewhere cold
    not that i can see..im sure its here somewhere and sure its just a simple mouse click but i dont see it
  10. #10 Re: Effects of Case Relearn
    Florida
    Do you need a tech II/tuner to do a case learn? I heard you dont, it involves the e-brake and turnin the car on off a few times is this true?
  11. #11 Re: Effects of Case Relearn
    New Carrollton,MD
    I've heard you need a tuner aeroforec or snap on to do it have no idea what snap on is
  12. #12 Re: Effects of Case Relearn
    On HPT you go to the specials tab it's one of the menu bar buttons. Then case learn.
    Overall if your car is running great, you'll feel like you gain very little from a learn. However like FFDP said, there is a gain...just not one that we are likely to notice until the motor pops.
  13. #13 Re: Effects of Case Relearn
    Banned
    Sioux Falls, SD
    So with me dropping in a L32 motor, and car came with a l26. do i need to do a case relearn?
  14. #14 Re: Effects of Case Relearn
    New Carrollton,MD
    Motor POPS!?!?!? PLease say that means when i get into the throttle some?
  15. #15 Re: Effects of Case Relearn
    Banned
    Sioux Falls, SD
    pops as in blows up!!
  16. #16 Re: Effects of Case Relearn
    Feb 2009
    flintnasty MI
    Surprised that this has not been mentioned...
    The CASE learn allows your PCM to detect KR... Without it you will never detect KR, and run the risk of breaking things very easily.
  1. How do you perform a crank case relearn?
    By GOTIT4CHEAP16 in forum PCM Tuning
    Last Post: 08-16-2010, 06:28 AM
  2. No Relearn for Overkill PCM?
    By 04CompG in forum PCM Tuning
    Last Post: 09-14-2008, 07:12 PM
  3. Security Relearn
    By 04CompG in forum General Tech Discussion
    Last Post: 09-12-2008, 05:25 PM
  4. IAC relearn ASAP?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 08-29-2008, 12:23 PM
  5. Q: PassKey III Relearn - Spare PCM
    By TommyGloves in forum PCM Tuning
    Last Post: 05-13-2008, 08:32 PM
