Hey how much does a case relearn help you get full potential of tune? since i have to get one. Like what might i be missing without it?
your pcm wont detect misfires properly?
i dont believe it does anything...you dont have to do a case learn when you drop a new motor in your car that the computer hasnt seen before so why would you have to do one with a newly tuned pcm on the original motor? if that was the case wouldnt you need a relearn after every new sensor you put in?
A CASE relearn is an advanced way for the car to detect misfires, based on the relationship of the cam position sensor to crankshaft position sensor. Anytime you permanently intend to install a PCM that did not come directly out of your car, you need a CASE relearn
or touch the chain.
Its in there somewhere?
I've heard you need a tuner aeroforec or snap on to do it have no idea what snap on is
On HPT you go to the specials tab it's one of the menu bar buttons. Then case learn.
Overall if your car is running great, you'll feel like you gain very little from a learn. However like FFDP said, there is a gain...just not one that we are likely to notice until the motor pops.
So with me dropping in a L32 motor, and car came with a l26. do i need to do a case relearn?
pops as in blows up!!
Surprised that this has not been mentioned...
The CASE learn allows your PCM to detect KR... Without it you will never detect KR, and run the risk of breaking things very easily.
