Today when I was driving home from work i noticed that smoke was coming out from under my hood that smelled like burning coolant. When I got home i popped the hood and saw that coolant must have been flung all over on the belt side of the engine. So a little hard to tell what is leaking but I'm pretty sure it's the water pump that's bad. The reason is because for a while now I have had a loud grinding type noise from the passenger side of the engine and I'm guessing its a bad bearing or pulley. I was waiting for it to warm up a little before I checked it out, most likely this weekend. So im just going to replace the water pump because my guess that's the problem. I did the lim and uim over the summer and that solved my coolant loss until now.
I looked up on here posts on how to change it out and seems pretty easy but I do have some questions. Just wanted to see if it matters what pump I buy or if anyone recommends a certain one. Im probably just going to buy it at autozone or murrys. The second question is that I found some people saying to use RTV on the engine block gasket and some saying not too, Is it a good idea to use it for a better seal? Im also going to change the upper and lower coolant hoses because they are also original and look a little wet near the clamps.
Any opinions on this will help as I've never had to buy one and dont know if all the pumps are basically the same.
Thanks
