I just bought a 1990 Pontiac Grand Prix LE, and it has a problem. The instrument cluster does not work properly... The speedo reads 15mph high when at 30mph and 25mph high when at 40mph. Seems that the higher the speed, the more the speedometer is off. The tachometer shows 3k at idle, when I know its not really that high and it goes far past the red befor shifting( automatic trans). The low fuel indicator light is always on no matter how much fuel it has. The oil pressure and battery voltage gauges always read almost at max. The "Check Gauges" light is always on (duh), and I am pretty sure the trip meter and odometer are off, as in, it says I have gone further than I have.
I have read that the instrument cluster screwing up is a common problem with this year Grand Prix, but is there a way to fix it without replacing the cluster? If there is not... I found a used instrument cluster on ebay that is said to fit the 1990 grand prix. However it does not have a tachometer. Will this effect anything? I prefer to have a tachometer, but I guess I could live without it. Thank you in advance of any help.
