Thread: Advice on lifter replacement
Results 1 to 4 of 4
  1. #1 Advice on lifter replacement
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    Well, the time has come to replace my lifters.There yellin at me whenever i start the car on a cold day.So i was wonderin if anyone has some doos or donts or general advice that a first timer might not know.I have the 78 dollar felpro gasket kit and the lifters i got from summit.I have built 2 motors b4 but they were both old ford v8s.I also have had a look at the lifters in 33 min video on here (without sound lol) so ive got the general idea.But any advice would be helpfull, Thanx!
    1998 GTP Mods: Getrag 5 speed ,balanced bottom end,ARP hardware,L32 rods,Federal pistons .20 over,XP Cammed,Double roller,130# springs,and 3.4 Gen V,SSC springs,GMPP sways, C5 calipers,12 inch brakes.2000 Grand Prix SE 3.8 Mods: GT dual exaust,plog,downpipe,Transgo Shift kit,1.9 yella terra rr,strut braces,gmpp kit.Both noob tuned with HP Tuner
  2. #2 Re: Advice on lifter replacement
    SE Level Member Gorecki's Avatar
    Nov 2010
    Maryland, US
    A couple of suggestions is to make sure you actually have a problem, *I believe* yours are like most later models and are roller lifters and not flat tap it. With these it's not uncommon to get a bit of tapping cold and oil pressure hasn't come up yet on an engine with some miles. Automatic timing change can cause a bit as well. So there maybe nothing really wrong other than some minor lash adjustment and making sure the lifters are/aren't okay in general.
    If you do verifiy you've got warn lifters it's likely they've worn on the cam as well. In anycase a partial fix on these assemblies could cause more harm than good.
    As you've got some rebuild experience I'm sure a lot of this rings a bell or two.
    [TRADED] 2005 Grand Prix Silver
    K&N Air Filter, NGK TR55GP G-Power Plugs, Delphi OE Wires, Timken Bearings, Mobil 1 Synth ATF & Oil, Purolator PureOne Filter
  3. #3 Re: Advice on lifter replacement
    redneck tennessee
    Thanx for the input, and you are right about the roller lifters.I dont like to use that stupid like button so THANK U I am pretty sure its the lifters but i understand i may run into other worn parts that need 2 be replaced.
  4. #4 Re: Advice on lifter replacement
    Portland Oregon
    If you have enough damage that the cam is worn then something else failed. As for the lifters you are 100% safe to replace them on a roller setup without worry on hurting the cam. Soak the lifters beforehand in a pan of oil to fill them up. This will prevent any damage internally to the lifters during first startup. Also you will need to replace the rocker bolts with new ones as they are torque to yield. If you plan on modding in the future you can get re-usable comp cams rocker bolts from vendors like Zzperformance.
  1. Engine ticking still, After lifter replacement.
    By 02grandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2011, 01:58 PM
  2. Advice on gasket replacement
    By ajnelson4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2010, 12:46 PM
  3. Lawngoose's Replacement Engine Advice/Question Thread
    By Lawngoose in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2010, 10:55 PM
  4. Front to rear brake line replacement - need advice
    By bxfl in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2010, 09:56 AM
  5. Lifter replacement
    By kfish in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2009, 05:35 PM
