Hello all-
I am looking for some comments relating to a 2005 GTP Comp G. I purchased my car October of 2009 and since have had the "Service Traction System" & Service Stability System" illumination lights come on at least 10 times. This only happens at start up and all it does is flash these lights in my DIC and turn of traction control. Then if I turn the car off . . . the lights are gone.
I have taken my car to the dealer for this issue every time. Initially there were a number of other issues they have since been able to fix but not this one. The first issues were - my car wouldn't shift from 2nd to 3rd it would simply bounce off the rev limiter. I also had twice where my vehicle spuddered out on me in 2nd gear would say "reduced engine power" and 10 seconds later shut down and wouldn't start for about 10 minutes. After that it would start but run like hell. Had to have it towed to the dealer twice.
Lucky for me I bought the car GM Certified so I haven't paid a dime for the work but here is what they replaced so far . . . catalytic converters, boost control pressure sensor?, all intake hoses to/from supercharger, 1 or 2 fuel injectors, spark plug wire or two, steering shaft, left rear wheel bearing, automatic climate control unit, reflashed pcm - then eventually replaced, traction/stability/etc module, all wiring/connectors to and from traction/stability module.
All issues are fixed except the traction/stability problem. Last I heard from the service manager was the GM Tech he spoke with said "they only made a couple hundred or couple thousand cars optioned that way and we don't know what the cause is". The service manager said that's not gonna work and eventually convinced them to look further into the problem.
So . . . within the next 24 to 48 hours they are sending out a GM district specialist to look at my car. Please post your feedback if any and if you have had this similar problem. I am very interested to hear your responses.
Thanks!
