Thread: speedo cluster not working...
Results 1 to 13 of 13
  1. #1 speedo cluster not working...
    Donating Users
    Parma, Ohio
    alright im not to familar with the speedo cluster. today while driving down the highway, my RPM gauge drops to 0, car is still running, every other gauge works. the only other thing that was tripped is the TCS was also shut down.
    Any thoughts would be helpfull.
    2003 Subaru Impreza WRX
    2008 Saturn Aura
    2000 Bright Red GTP coupe. RIP 11/6/11
  2. #2 Re: speedo cluster not working...
    MO
    http://www.grandprixforums.net/cps.php
    crankshaft position sensor
    <brandonl2000> LMAO D!!
  3. #3 Re: speedo cluster not working...
    Donating Users
    Parma, Ohio
    thanks for the info on it
    2008 Saturn Aura
  4. #4 Re: speedo cluster not working...
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Wouldnt the CPS cause his car to stop running? He said even when at 0rpm it ws running fine. Normaly with a CPS you get a stall with trouble restarting
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  5. #5 Re: speedo cluster not working...
    Donating Users
    Parma, Ohio
    from what i read, not always, but either way it started working again this morning, and was fine on my 55 mile commute.. planning on replacing it this weekend, and hopefully it wont die prior to that.. would like to hold out a little longer on replacing it, so i can do my rebuild then as well. but i drive way to much.
    2008 Saturn Aura
  6. #6 Re: speedo cluster not working...
    Jul 2010
    Michigan
    If it is the CPS it could start to stall randomly just be ready for it to happen in the most inopportune moments. Mine always acted up on the coldest days possible
    2005 GTP Grey
  7. #7 Re: speedo cluster not working...
    Donating Users
    Parma, Ohio
    yeah it was about 30 degrees last night when it cut off. but only about 25 this morning when it was fine..
    2008 Saturn Aura
  8. #8 Re: speedo cluster not working...
    I've seen a CKPS do both random stalls and just kill rpm.
  9. #9 Re: speedo cluster not working...
    Jul 2010
    Michigan
    hmm learn something new every day :P... Why couldnt mine be so nice as to just kill RPMs... I guess the Bonnie just liked to keep me stranded
    2005 GTP Grey
  10. #10 Re: speedo cluster not working...
    Donating Users
    Parma, Ohio
    yeah i hope not.. my commute is far to long to be doing that
    2008 Saturn Aura
  11. #11 Re: speedo cluster not working...
    Mine never stranded me.. it hiccupped at highways speeds. Made it really tough to figure out.
  12. #12 Re: speedo cluster not working...
    Donating Users
    Parma, Ohio
    My car stalled once today while sitting at a stop light.. fired right back up tho no problems..first time it's ever done that.
    so most likely its related?
    2008 Saturn Aura
  13. #13 Re: speedo cluster not working...
    Tough to say. If it stalls from running fine w/o symptoms like rpms bouncing or tough time holding idle etc, then I'd say ...It could be.
    Mine was tough to diagnose because it didn't stall, didn't do it at any other time than highway speeds and when it finally gave me a crank sensor code was the same time I scanned it and saw the runtime counter reset.
  1. Gauge Cluster Not Working
    By DreadMcLaren in forum 04+ Specifics
    Last Post: 04-13-2015, 11:13 AM
  2. Speedo vid
    By siLversLeigh in forum Track Sessions and Kills
    Last Post: 06-04-2010, 09:42 AM
  3. Working on a digital gauge cluster project...
    By BackInBlack in forum Visual/Body Modifications
    Last Post: 09-22-2009, 02:53 PM
