Thread: power windows problem
Results 1 to 6 of 6
  1. #1 power windows problem
    Albertville
    my moms 2002 grand prix has some window problems. if a window switch is bad, could it cause the back windows to not work, not getting any power? the driver and back windows wont move, but the passenger works fine. the switch clicks when you press it. what could be wrong?
  2. #2 Re: power windows problem
    SE Level Member kentpappy's Avatar
    Nebraska
    Could be the switch, unhooked wire, bad relay, bad motor, etc.
    2000 ZX12r (Big bore kit, Cam, 6" Extension )
    1999 Escort ZX2 (DD)
  3. #3 Re: power windows problem
    SE Level Member tranny trouble's Avatar
    dewberry alberta canada
    i to have problems with windows, pass side very slow, drivers side slow and stops and wont go some time,, has there been a history of these motors not working or wearing out easly, it is a 97, but had older trucks and such that didnt have this problem,, so need help,, is it the motors, or is there a lazy relay or some other area i should check??????????
  4. #4 Re: power windows problem
    Donating Users
    Yorkville, IL
    My 03 is like that too. I think its just my drivers side switches going out. Three windows will roll down and the other one wont I either just keep clicking the switch and it will finally work or go to the door that the window isnt rolling down on and use that switch and it works fine. It doesn't do it every time just randomly.
  5. #5 Re: power windows problem
    Apr 2011
    las vegas
    Typically the window regulator. I had three go out at once.
  6. #6 Re: power windows problem
    SE Level Member MOTELETJR's Avatar
    Houston, Texas, United States
    I have an issue where only my driver and back passenger window work from cluster. Passenger window works from passenger switch, Driver back window doesnt work at all. Replaced driver cluster and still same exact problem. What is going on? Does Relay work all 4 windows? Where is it located?
  1. Repair Your Power Windows Switch[*]
    By J_Ferguson in forum How To Write-Ups/Tech Tips
    Last Post: 10-19-2013, 01:07 AM
  2. power windows, locks, moonroof, interior lights not working!! HELP!
    By rottenhippo in forum General Tech Discussion
    Last Post: 10-30-2010, 02:19 PM
  3. Power Windows Help Needed...
    By MHolla in forum General Tech Discussion
    Last Post: 07-11-2009, 08:50 AM
  4. Power Windows
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-12-2008, 08:51 PM
  5. Power Windows
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-08-2008, 03:58 AM
