Thread: HOW to and is it HARD?
Results 1 to 14 of 14
  1. #1 HOW to and is it HARD?
    May 2008
    McHenry IL
    I discovered that a 180 t-stat is only like 9 bucks at autozone.. what is the big deal and hype on this item?? more hp or something? is it hard to install 1 and how do u install it? if i get enough help and its fairly simple ill go to autozone tomarrow morning and install her lemme no guys thanks. PS: remember i am a noob haha. but a cool noob like rambo
  2. #2 Re: HOW to and is it HARD?
    May 2008
    McHenry IL
    rambo isnt a noob though i just wanted to put the avatar with the gun haha rambo popped in my head go figure
  3. #3 Re: HOW to and is it HARD?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  4. #4 Re: HOW to and is it HARD?
    May 2008
    McHenry IL
    sweet that sums it all up thanks alot man but what is the point of a 180 t stat?
  5. #5 Re: HOW to and is it HARD?
    TDCRacing
    Guest
    The theory behind the whole thermostat thing in general is more hp....will you get any or see any gains other than the temp needle not going as high...no...lol
  6. #6 Re: HOW to and is it HARD?
    May 2008
    McHenry IL
    so its pretty much pointless?
  7. #7 Re: HOW to and is it HARD?
    TDCRacing
    Guest
    Well i have a 160 so i cant say that lol....i mean i dont see it hurting anything...a cooler engine usually lasts longer...but the fan will still come on at the same time because you dont have a tuner......so it would only help you when driving constantly....put 2 gallons of gas in your car for 8 bucks and call it a day lol
  8. #8 Re: HOW to and is it HARD?
    TDCRacing
    Guest
    your on the right track....do reaserch before doing any mods (saves money)...and get more than one opinion....
  9. #9 Re: HOW to and is it HARD?
    PA
    Yeah, personally I used to run with a 180° stat up until recently. Anymore when I drive my car, I try to get the best mileage possible. And you will get better mileage with a stock stat. The 180° stat will cause lower mpg.
    The idea behind it is to keep the engine running cooler, thus keeping the incoming air cooler and more fuel. Some people would also put them in to keep the engine cooler to combat KR. But if you have a CAI, you won't need to worry about the incoming air so much. And if your car is modded correctly, you shouldn't have to worry about KR. So it is really a moot point.
    You can do what you want, but I will not be running a cooler stat, except for at the track.
    2001 GSE
  10. #10 Re: HOW to and is it HARD?
    May 2008
    McHenry IL
    ok screw that idea o and yeah i topped of my car today ITS ON F thats like WOW lol rare! haha
  11. #11 Re: HOW to and is it HARD?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Don't run a 160*, it's not good for the engine. 180* is optimal for performance and the stock for MPG.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  12. #12 Re: HOW to and is it HARD?
    TDCRacing
    Guest
    Quote Originally Posted by GTPJOE90 View Post
  13. #13 Re: HOW to and is it HARD?
    Barksdale AFB, LA
    F is your wallet screaming "f*ck!!!"
    I just switched back to a stock tstat from a 180. Didn't notice any gains, and did notice a slight drop in MPG. An internal combustion engine is most efficient at 195* +/- a few, so that's why the stock tstat opens at that point.
    2009 Subaru Impreza WRX STI
  14. #14 Re: HOW to and is it HARD?
    May 2008
    McHenry IL
    ok i understand thanks for clearing it up for me every1. STOCK t-stat it is
  1. For all your hard to find car part needs!
    By Reptile in forum Off Topic Discussion
    Last Post: 05-09-2008, 09:13 AM
  2. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
  3. Shifts are pretty hard...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2008, 11:13 AM
  4. hard shift between 1rst and 2nd
    By gp2004_compg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2008, 06:56 PM
