Thread: Cruise Control stopped working
Results 1 to 17 of 17
  1. #1 Cruise Control stopped working
    Apr 2008
    Hello,
    A few days ago when I was driving home I was using cruise control but had to slow down so I clicked the switch to the far left off position and when I could got back upto speed and tried to set the cruise control again yet this time it wouldn't work. I tried shutting off the car, tapping the breaks, checked the fuse and nothing helps. I am going on a long 12 hour drive at the end of this week and really will be needing cruise control to work or it's going to be a long trip . If anyone can please help me on what I can do or if it is best for me to just take it to a shop? If i do take it in how much is it going to cost to get fixed? What is the likely problem? Thank you in advance!
  2. #2 Re: Cruise Control stopped working
    Oklahoma
    I remember seeing some information stating that if the bulb(s) went out in your third brake light that that would cause the cruise control to not work. Dont ask me how, I just remember seeing that so it might be worth checking.
  3. #3 Re: Cruise Control stopped working
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    i remember reading this somewhere, but dont recall if it was for these cars or another GM product.. either way, doesnt hurt to check.
    ... though it could be the switch itself, also...
  4. #4 Re: Cruise Control stopped working
    Apr 2008
    How do I check that which is the 3rd brake light?
  5. #5 Re: Cruise Control stopped working
    Oklahoma
    Well you'll kinda need a helper. Some one to stand behind the car while you hit the brakes and see if that light lights up.
  6. #6 Re: Cruise Control stopped working
    Apr 2008
    Tried it and the brake lights all work, I checked all my lights and everything is working. Still no cruise control. I made an apt. with a auto place close to my house I really wanted to get this fixed before I left on my trip friday though and they can't get me in till monday.
    If anyone has anything i can try to check out please let me know I am up for any suggestions.
  7. #7 Re: Cruise Control stopped working
    SW Chicago Suburbs
    i am not sure, but maybe there is a fuse for the CC? i dont think there is, but woouldnt hurt to check
  8. #8 Re: Cruise Control stopped working
    Apr 2008
    There is under the glove box and I checked it and it is fine. That would've been too simple right lol?
  9. #9 Re: Cruise Control stopped working
    Feb 2008
    West Jordan, UT
    I'm pretty sure that the second cable on the throttle body controls your cruise control. My cruise control doesn't work either, and the little connector for my cable is broken. I found this topic while searching to see if that could be my problem. If this sounds right to anyone else, do you know where I can get a new connector? If you don't know what I'm talking about, I can take pics later.
    Edit: Sorry about the thread hijack.
  10. #10 Re: Cruise Control stopped working
    Apr 2008
    Quote Originally Posted by spenc938 View Post
    Could you please post pictures of what you are talking about so I can check mine out? and dont worry about thread hijack lol we are on the same subject
  11. #11 Re: Cruise Control stopped working
    Feb 2008
    West Jordan, UT
    Taking pictures now. I will edit in a few minutes.
    Edit:
    Click for large versions.
  12. #12 Re: Cruise Control stopped working
    Apr 2008
    K thanks
  13. #13 Re: Cruise Control stopped working
    Feb 2008
    West Jordan, UT
    Bump. Anyone?
  14. #14 Re: Cruise Control stopped working
    May 2008
    McHenry IL
    maybe a loose vacum hose?? just an idea. hope you get er done n fixed =]
  15. #15 Re: Cruise Control stopped working
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    i actually had this happen to me, but when i got my gauges installed by someone they ****ed something up and my brake lights stayed on causing my cruise control not to come on because it thinks i am pressing on the brakes...so make sure your tails are all good
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  16. #16 Re: Cruise Control stopped working
    Feb 2008
    West Jordan, UT
    I'm quoting myself from the front page, because most people probably don't read the whole topic.
    Anyone have any thoughts on that.
  17. #17 Re: Cruise Control stopped working
    TDCRacing
    Guest
    dealer and yes the second cable controls the cruise control. that dealer may only sell the whole cable. not sure on that
  1. Cruise Control Light
    By Darkcelle in forum Off Topic Discussion
    Last Post: 06-12-2008, 06:13 AM
  2. HUD Stopped Working After Huge Speed Bump
    By AmericaFcukYeah in forum General Tech Discussion
    Last Post: 05-24-2008, 12:13 PM
  3. Twin city cruise night april 12th...Illinois
    By gp4u2c in forum Shows and Events
    Last Post: 04-03-2008, 09:28 AM
  4. Replies: 14
    Last Post: 02-10-2008, 12:37 PM
  5. hvac control
    By Chleby in forum General Tech Discussion
    Last Post: 01-17-2008, 11:53 AM
