Thread: change low beam daytime running lights
Results 1 to 19 of 19
  1. #1 change low beam daytime running lights
    Dec 2010
    earth
    well here I am again, 2002 grand prix
    HI, I just changed my headlights to Halogen High Beam and HID low Beams. Now my Daytime running lights (DRL) are my HD low beams and I would Like them to be the Halogen HI Beams/ Have you any suggestions? Is there a wire I can change over from Low to hi beam?
    Any info greatly appreciated
    regards
    Russ.
  2. #2 Re: change low beam daytime running lights
    Never Never Land
    just disable the drls. easiest, quickest, IMO the most effective
  3. #3 Re: change low beam daytime running lights
    GT Level Member jakewet28's Avatar
    Cincinnati
    Why would you want your high beams on during the day? You'd be blinding everyone during the day. Just disable them like he said^
    VS Cam, SS Intercooler, Powerflow catback, SSAC headers, open cone, 180* tstat, 42.5lb injectors, 2.8 pulley, 3.29 gears, zzp pcm, all supporting mods
  4. #4 Re: change low beam daytime running lights
    Dec 2010
    earth
    Canada it is a law for DRL.
    HI beam would only appease the police , they dissipate so quickly in daylight you would only see the yellow glow.
  5. #5 Re: change low beam daytime running lights
    Never Never Land
    can a fog light count as a drl? If you REALLY need it just turn your headlights on when you get in.....DRLS are gonna kill your HID quick.
  6. #6 Re: change low beam daytime running lights
    Dec 2010
    earth
    OK . the Headlight switch it is. Now can I pull a fuse to stop the lights from flashing when I remotely lock the car?
  7. #7 Re: change low beam daytime running lights
    Never Never Land
    theres a link around here...ill find it...i had to find it for miker56 last night too...its in the owners manual also.
  8. #8 Re: change low beam daytime running lights
    Never Never Land
  9. #9 Re: change low beam daytime running lights
    Never Never Land
    You know how to disable the drl's right?
  10. #10 Re: change low beam daytime running lights
    Dec 2008
    Lawndale, CA
    Use backinblack's page for reference to disable the DRL's. He has a lot of information in there as well if you want to disable the automatic headlight feature and manually control rhem.
    Headlamp Control
    Also you can reroute the DRL's to the fogs.
    DRL circuit Re-route to fog lamps
    You can do this to have the corners flash instead of the headlights to not burn out the ballasts.
    ClubGP:
  11. #11 Re: change low beam daytime running lights
    Dec 2010
    earth
    Thanks guys. I will read these and try one. I will post back to let you know if I succeeded.
  12. #12 Re: change low beam daytime running lights
    Dec 2010
    earth
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    I am trying to find out.
  13. #13 Re: change low beam daytime running lights
    Never Never Land
    when you open the driver door thers a little cover thingy. pop that off and inside is a heat sink with a connector on it..disconnect it and done....ive had mine like that for quite a while and it works fine. I'm sure theres other ways but I think thats the easiest.
  14. #14 Re: change low beam daytime running lights
    Dec 2010
    earth
    Thank you. will do
  15. #15 Re: change low beam daytime running lights
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Quote Originally Posted by rcranium View Post
    in ontario its not a law to have drl's
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  16. #16 Re: change low beam daytime running lights
    Dec 2010
    earth
    Quote Originally Posted by Rather B Blown View Post
    Federal Motor Vehicle Safety Standard 108 - Wikipedia, the free encyclopedia
    Canada's analogous regulation is called Canada Motor Vehicle Safety Standard 108 (CMVSS 108)
    CMVSS 108 requires daytime running lamps on all vehicles made since 1 January 1990,
    well I need them in BC
  17. #17 Re: change low beam daytime running lights
    Never Never Land
    you get it done?
  18. #18 Re: change low beam daytime running lights
    Dec 2010
    earth
    Thanks for all the explanations and help. so far so good. all is well.
    low beam outshines the Halogen Hi-beams and the fancy ion spark fog lamp replacements look good but not much more light on the road (I believe it is because of the HID low beams)
  19. #19 Re: change low beam daytime running lights
    usa
    LED Daytime running lights (LED DRL) are a low-cost method to reduce crashes. It can improve the noticeability and detectability of vehicle in the central and peripheral fields of view.
  1. 02 GTP Daytime Running Lights
    By techweenie in forum Audio, Security & Visual Electronics
    Last Post: 05-05-2010, 06:39 AM
  2. daytime running lights
    By 03renegade800 in forum General Tech Discussion
    Last Post: 08-16-2009, 07:06 PM
  3. A/C and Daytime running lights
    By hydrashok158 in forum General Tech Discussion
    Last Post: 08-14-2009, 09:06 AM
  4. How to disable daytime running lights.
    By ChvyTrcksFrdScks in forum How To Write-Ups/Tech Tips
    Last Post: 05-09-2009, 04:15 PM
  5. Daytime running lights
    By Girevik in forum General Tech Discussion
    Last Post: 01-05-2009, 12:40 PM
