Thread: Charging Sytem Failure Warning
Results 1 to 11 of 11
  1. #1 Charging Sytem Failure Warning
    Feb 2010
    Rockton, IL
    Okay, so the other day I was just driving when I hear that ding you never want to hear. I look over and it flashes "Charging System Failure". Now the main question is, what all could this be? I have left it on the battery voltage and have watched it fluctuate anywhere from 14.9 volts to under 12.5... that amount of fluctuation can't be normal if everything is running correctly could it? What could be causing the problem?
  2. #2 Re: Charging Sytem Failure Warning
    Charles City, IA
    Shorted diode in the alternator.
    SMGPFC Two Nipple General
  3. #3 Re: Charging Sytem Failure Warning
    Feb 2010
    Rockton, IL
    That's exactly what I want to hear lol
  4. #4 Re: Charging Sytem Failure Warning
    Pennsylvania
    Did you install ZZP's "voltage booster?"
    Edit: For those that thought I was suggesting a fix, the voltage booster will often set off the charging system failure alert.
  5. #5 Re: Charging Sytem Failure Warning
    Feb 2010
    Rockton, IL
    nope, car is bone stock... it has had 30k miles put on it since January. Only thing that is different is no front plate after that deer, and that guy backing into me at McDonald's.
  6. #6 Re: Charging Sytem Failure Warning
    Dec 2010
    Ohio
    Look into the jumper box under the red cap on the pass side. I had the same problem a while ago and the darn nut was loose. I looked at everything and that slipped my mind.. After some bad words and some scratching of the head.. Simple!! I felt soooo stupid.. Wow!!
  7. #7 Re: Charging Sytem Failure Warning
    Feb 2010
    Rockton, IL
    First instinct was to jump under the hood and check for any corrosion on the terminals of the battery, just because that had been the problem in any of the other cars that went out. There was a little bit of corrosion that I got off pretty much by blowing on it, but the cables were secure.
  8. #8 Re: Charging Sytem Failure Warning
    you need to scrub them to actually clean them.
  9. #9 Re: Charging Sytem Failure Warning
    Donating Users Rust's Avatar
    Jun 2010
    Canada
    Mine came on 3 times in 1 week before my battery pooched soon after the cold weather hit.
    There is no putting it off till later if your car won't start.
  10. #10 Re: Charging Sytem Failure Warning
    Feb 2010
    Rockton, IL
    That's the thi, my car has been starting just fine. Its been running fine, it's just the battery voltage keeps fluctuating. And to be fair I did scrub the terminals, I was just trying to point out how little was actually on there lol
  11. #11 Re: Charging Sytem Failure Warning
    SE Level Member powerranger262's Avatar
    Nov 2009
    Quote Originally Posted by Cwebb0267 View Post
    Where/what is said "jumper box".
    2004 Grand Prix GT 3.8L
  1. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  2. HELP car not charging
    By JoshsGTP in forum General Tech Discussion
    Last Post: 09-18-2010, 11:22 PM
  3. Question about charging the A/C (97 GT)
    By tesmith66 in forum General Tech Discussion
    Last Post: 04-28-2010, 10:26 AM
  4. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
  5. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
