Mounted under the dash on a 97 gtp?
anyone?
I see nothing in the owners manual
TIA
anyone?
TIA
HUH? Never heard of a tire calibration button. If you mean the speedos off because you added taller wheels then you need to tune the pcm for it
I remember reading somewhere about the very first GTPs using the ABS encoders to check for wheel air pressure drops (presumably by monitoring their radius as it changes due to a pressure loss). Maybe this is that
yeah its a tire pressure button mounted to the knee bolster where your right leg (shin) is.
It's def a factory button and wiring plug...looks like the trunk release button in the glovebox.
Anyone else have this button?
I have the button its to reset the check tire pressure light in the DIC
only 97's came with that, its kind of stupid, you hold the button until the dummy light flashes on the dic, then you drive around for 10 minutes iirc. If the dummy light on the dic doesn't flash, your tire pressure is good. 97 gtp's don't have traction control either.
There is a lot of stupid little things on 97's. Tuning is a real pita on 97's.
