Thread: car trouble
Results 1 to 6 of 6
  1. #1 car trouble
    Jul 2010
    little river texas
    I have a 94 gp 3100 and for the past couple months it has been running bad. Some times when i start my car it starts up and just dies, and when i try to start it up again i have to give it gas and hold the rpms around 2k for a few min before i can just let it idle alone. It also happens when im stoped at a red light i have to hold down the gas peddle to keep it from dying. I thought it may have been the alternater (at night i noticed my lights dimming in and out like they werent getting the right amount of power) but it seems to be fine. Any advise is welcome. Thanks for the help
  2. #2 Re: car troble
    Denver
    Your lights dimming might be result of low idle.
    There are a million things this could be....you're going to have to provide more information and do more detective work.
    Start with the basics:
    1) Pull and inspect the plugs
    2) Check the air filter and fuel filter
    3) Check the throttle body for large amounts of carbon buildup
    4) Check for other rudimentary problems (broken vacuum lines, broken wires, leaking fluids etc)
  3. #3 Re: car trouble
    Jul 2010
    little river texas
    Car has new air filter, new plugs and wires, throttle body is clean, all vacuum lines have been replaced. The only thing that leaks is oil as does every other 3100 engine. The fuel filter was changed 2 years ago, how ofter should that be done?
    Iv been told it could be the egr valve going out or one of the many sensors on the engine.
  4. #4 Re: car trouble
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    maf? spray it down with some specialty cleaner...
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  5. #5 Re: car trouble
    Jul 2010
    little river texas
    What is maf?
  6. #6 Re: car trouble
    Denver
    Mass Air Flow sensor.
