Thread: Speakers & Ipod
Results 1 to 8 of 8
  1. #1 Speakers & Ipod
    Sorry if this is the wrong area to post. I have a 2003 Grand Prix and bought new 6x9's for it. Can someone explain to me how to remove the old and install the new? Also, is there a place I can plug in an ipod cable directly to the cd player so I don't have to use iTrip? Everything is factory right now.
    I don't know too much about cars so detailed instructions are appreciated Thank you!
  2. #2 Re: Speakers & Ipod
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Q #1)To get to the speakers you have to remove the backseat.
    How to Remove rear cushion:
    1. Pull cushion release tabs right underneath cushion and remove cushion
    Removal rear seat back:
    1. Remove small nut on each side of bottom
    2. Remove large nut on each side of bottom also holds seat buckles
    3. Top is just held in by hooks. Pull bottom off of mounting bolts and lift to remove
    The package tray then needs to be pulled up slightly and then it should be able to pull out. You can get to your speakers now.
    Q #2)does the car have a cd changer? if so you can buy an easy plug and play unit to convert the cd changer plug to an aux plug for your ipod.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  3. #3 Re: Speakers & Ipod
    No, I don't have a cd changer. Is there a way I can do it without one?
    Thx for the speaker help, hopefully I can make figure that out!
  4. #4 Re: Speakers & Ipod
    alhambra, Il
    I am sure there is ways to do it w/o any options on the stereo like a cd changer/tape/sat radio but it isn't easy.
    is their a tape or aux button on the front of the radio?
    Steven Oliver
  5. #5 Re: Speakers & Ipod
    May 2008
    Portsmouth, NH
    iPod Car Stereo Installation Guide
    "Wired FM modulators
    To install a wired FM modulator, first find a good mounting location. Keep in mind that you will need to access your factory radio's antenna input, and connect the iPod to the modulator. Common locations include under a seat, behind an interior panel, and in the cavity behind the receiver.
    FM modulators require a 12-volt connection to a switched (on/off) source. Since you have to remove your radio to get to the antenna input, you'll have easy access to the power and ground wires in your factory radio harness. If you don't want to splice into your factory wires, you can make the power connections at your fuse panel. Look for empty fuse holders and insert fuse taps. You'll also have a black ground wire that must be secured beneath a nearby screw that makes contact with bare metal on the body of the vehicle.
    Following the instructions on your Crutchfield MasterSheet™, remove your receiver from the dash and unplug the antenna from the rear of the unit. Plug the vehicle's antenna cable into the antenna input on the FM modulator. Next, run the output of the modulator to your receiver's antenna input (certain vehicles require antenna adapters — use the online Vehicle Selector or call a Sales Advisor to inquire about a specific vehicle). If this leaves slack in your antenna lead, tie it up so it won't fall down and interfere with anything.
    Most wired FM modulators accept RCA inputs, so you'll need a minijack to RCA cable to connect your iPod. Once you have connected the iPod, determine which of the available modulation frequencies is least likely to be shared by a strong local radio signal and set it on the hideaway box before you mount the unit (on some models you can change this setting on the fly)."
    Evidently it offers MUCH better sound, as the signal is sent from your iPod directly to a converter and through your stock radio's antenna port on the back of the stereo. This might work for you.
  6. #6 Re: Speakers & Ipod
    alhambra, Il
    I don't know why I didn't think of those, but then again I haven't installed any for ipods. I know they work really well with satellite radio, when I install them.
    Steven Oliver
  7. #7 Re: Speakers & Ipod
    Oh my god! I have no idea what any of that means?? Any of you in San Diego want to do this for free? Haha, just kidding.
  8. #8 Re: Speakers & Ipod
    "Auxiliary inputs" from that website.
    I want to do that one. How do I go about removing my stereo?
    I am so worthless when it comes to cars :/
  1. no rear speakers
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2008, 06:44 PM
  2. Ipod touch software
    By scooz14 in forum The Rant Forum
    Last Post: 02-24-2008, 01:14 AM
  3. custom ipod mount for the 97-03 guys
    By s1795so2 in forum Audio, Security & Visual Electronics
    Last Post: 02-04-2008, 08:01 PM
