Thread: OBDII scanner/tool recommendations
Results 1 to 13 of 13
  1. #1 OBDII scanner/tool recommendations
    Denver
    I'd like to own a tool (rather than continue to borrow) that can scan codes and monitor engine properties (like KR etc).
    Can you recommend something that's not too expensive?
  2. #2 Re: OBDII scanner/tool recommendations
    This kinda depends on what you'd like from the tool.
    Options:
    Portability
    Programming ability
    Generic for various models/makes
    Low cost
    Some of the guys with Droid/iPhones have found an OBDII connector and a programe called Torque. Not sure if they've had success scanning KR yet. May be a nice low cost way. I'm not very familiar with this one.
  3. #3 Re: OBDII scanner/tool recommendations
    Denver
    Let me clarify:
    I have a laptop so wouldn't be opposed to having an interface to my laptop (if there is a cord with a program - I can sit the laptop in my passenger seat if need be)
    I don't have an iPhone/Droid (although my wife does) and have little interest in this anyway
    I'm looking for something less than about $200 or so
    I don't care about programming (i.e. I just want to pull data and not change it etc)
    I do want it to operate on multiple cars - we have three right now so I don't want this to be specific to my 1998 GTP. I also have a 2005 GTP and a 2005 Monte I might use it on (plus we're looking at replacing my wife's monte with a 2009 MKX)
  4. #4 Re: OBDII scanner/tool recommendations
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    I have the scangauge II and it reads KR and a bunch of other engine parameters. and it reads codes. It gets the job done!
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  5. #5 Re: OBDII scanner/tool recommendations
    Nov 2009
    Grand haven
  6. #6 Re: OBDII scanner/tool recommendations
    Denver
    Quote Originally Posted by shawngtp View Post
    I was looking at this earlier.
    Can you confirm that this does KR?
  7. #7 Re: OBDII scanner/tool recommendations
    GT Level Member sic6's Avatar
    san marcos, tx
    Harbor frieght has a pretty good one. Reads and graphs live data. Have'nt used it to read kr yet though.
    CAN OBD II Code Reader/ EOBD Scanner
    I mostly use autoenginuity though, so far its the best pc based scan tool i have used so far.
    AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
  8. #8 Re: OBDII scanner/tool recommendations
    Nov 2009
    Grand haven
    Quote Originally Posted by SJAndrew View Post
    No it does not.
  9. #9 Re: OBDII scanner/tool recommendations
    Denver
    It looks like the Actron 9185 @ $210 or so monitors KR. Does anyone have any experience with this one?
  10. #10 Re: OBDII scanner/tool recommendations
    SE Level Member BlackGS's Avatar
    Central Jersey
    It's too bad the HPTuners scanner is so expensive ($349). It is clearly one of the best out there.
    HPTuners.com >> Performance At Your Fingertips
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  11. #11 Re: OBDII scanner/tool recommendations
    aeroforce gauges are decent for a permanent solution (Imo the only solution you should consider for KR since it can vary so easily.)
  12. #12 Re: OBDII scanner/tool recommendations
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    If you could find a LS1M used(they no longer produce them) that would be the best bang for the buck, as it scans and logs. It would work on any 3800 or ls1 vehicle.
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  13. #13 Re: OBDII scanner/tool recommendations
    Check out this GM Enhanced Software . It run great with this obd2 scanner.
    I've been using it for 2 years and you can read ABS, SRS and special powertrain codes.
  1. OBDII Codes [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-26-2011, 01:23 AM
  2. Obdii?
    By Viper in forum General Tech Discussion
    Last Post: 03-06-2010, 09:58 AM
  3. ECM To OBDII Connection
    By lstexan in forum General Tech Discussion
    Last Post: 02-07-2010, 03:05 PM
  4. OBDII Cable
    By BwolfGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2009, 03:22 AM
