Thread: Fuel Pump Issue
Results 1 to 5 of 5
  1. #1 Fuel Pump Issue
    Donating Users zildjian102's Avatar
    Wilkes Barre, PA
    I went to turkey hill tonight to get a coffee with my cousin, and when i came back out and started my car it sputtered and died.. when i turned the key back to the on position i noticed i couldnt hear the fuel pump, so i tried to start it and it wouldnt even turn over completely.. just kind of sputtering. then when i tried again it just kept cranking and thats it.. so i went under the car and hit the fuel tank a few times and had my cousin try to start it and sure enough it started! but now when the fuel pump primes its really low pitched and does not sound healthy at all.. the car starts though.. should i chance it and drive to work tomorrow or should i get it replaced tomorrow.. i dont know if i should risk it.
    2002 Grand Prix GT- top swap soon
    1997 Pontiac Grand Prix GTP-project/parts
    3.4 pulley, intense tune, SD headers, intake, 180 tstat, al104's
  2. #2 Re: Fuel Pump Issue
    Denver
    I had mine replaced not too long ago. They also added a resistor module and harness assembly that caused the pump to die.
    Bottom line: make sure you add this resistor/harness assy if you do any work on your pump. Check out here.
  3. #3 Re: Fuel Pump Issue
    Jersey
    i had that problem with my 97, i replaced the fuel pump and did a zzp re-wire
    16' wrx sti- stock
  4. #4 Re: Fuel Pump Issue
    Wilkes Barre, PA
    okay so its my fuel pump dying right? If so im ordering one as soon as i get my paycheck on friday
  5. #5 Re: Fuel Pump Issue
    GTP Level Member SuperSport's Avatar
    Michigan
    I would recommend one from Ed Morad or find a factory take-out from somewhere.
    Do not buy any brand of aftermarket fuel pump. The low price compared to OEM may lure you in but dont do it. Most aftermarket pumps are poorly built and youll be changing it out again in a year or so...
    Before you buy a pump, run power directly to it to confirm its dead. Or check the resistor too. If it is dead, then get a pump.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel Pump/Resistor issue
    By Pshnmeawy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2010, 07:51 PM
  3. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
