Thread: 1995 Grand Prix GTP ! Timing belt question
Results 1 to 12 of 12
  1. #1 1995 Grand Prix GTP ! Timing belt question
    SE Level Member Rockhound's Avatar
    Dec 2010
    Maryland
    My daughter bought the car from my Aunt who is the original owner, so we are second owners. The car died while she was driving it doing bout 35mph. Had it checked out and mechanic said needs a Timing belt. What are the chances the valves may be bent? It is a 95,, 3.4 DOHC 51,000 Miles on the car.. ,, and heard the interference motor came out in 96? Looking to sell the car either running or not because my daughter needs a small SUV for college as they get alot of snow in the winter. Is it worth spending the money to fix and how much do you think it should cost? Have pics of car if anyone interested
  2. #2 Re: 1995 Grand Prix GTP ! Timing belt question
    Charles City, IA
    I dont think the 3.4 was an interference engine. Having a shop do it it would probably be like $500-800.
    SMGPFC Two Nipple General
  3. #3 Re: 1995 Grand Prix GTP ! Timing belt question
    Dec 2010
    Maryland
    Thanks for the reply! So you think the valves are fine?? The car drove and ran great before this happened.
    Thanks
  4. #4 Re: 1995 Grand Prix GTP ! Timing belt question
    Charles City, IA
    Well I did a little research for ya, the 3.4l is not an interference engine so you should be fine replacing the timing chain.
  5. #5 Re: 1995 Grand Prix GTP ! Timing belt question
    Dec 2010
    Maryland
    Thank you for your help! Happy Holiday's to you and your family
  6. #6 Re: 1995 Grand Prix GTP ! Timing belt question
    Dec 2010
    Maryland
    you mean belt? I believe this motor has both timing chain and belt???
  7. #7 Re: 1995 Grand Prix GTP ! Timing belt question
    Charles City, IA
    Oh, sorry I was looking up the non ohc engine, I will look into it further.
  8. #8 Re: 1995 Grand Prix GTP ! Timing belt question
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    "One final work, while the 3.4L is not designed as an interference engine, it has happened that when the timing belt breaks or slips, the pistons can hit the valves. ther is only .010" designed clearance between the valve at full lift and the piston at top dead center. That is how my GP was when I got it. 6 bent valves, timing belt broken." Quote from the article THE 3.4 DOHC 24 VALVE
    Ao if it happened during low RPM normal driving Id say you're fine
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  9. #9 Re: 1995 Grand Prix GTP ! Timing belt question
    Dec 2010
    Maryland
    According to this link ,, it looks like I may be ok
    GM Timing Belt & Timing Chain Replacement
  10. #10 Re: 1995 Grand Prix GTP ! Timing belt question
    Charles City, IA
    Good to hear.
  11. #11 Re: 1995 Grand Prix GTP ! Timing belt question
    Dec 2010
    Maryland
    Just to give an update ! The valves were NOT bent,, and the 1995 3.4 DOHC is Not an interference motor. Had the timing belt replaced along with few other things ( tension pulley ) and the car runs great once again Just figure I let people know and it cost me $950. and he was a friend who did it. Had one garage quoted me estimate of $1300. Very happy with it or should say my daughter is, Hope this helps other people
  12. #12 Re: 1995 Grand Prix GTP ! Timing belt question
    Banned
    CT
    I had a Lumina Z34 about 8 years ago with the same motor. The timing belt snapped while I was WOT and there were no bent valves. Glad to hear your outcome was the same. Back then I wasn't too good at wrenching as it was my first car, and the job cost $1000.
  1. 1994 pontiac grand prix se timing belt questions
    By 1994grandprixse in forum 3.4L V6 (LQ1) DOHC
    Last Post: 09-02-2010, 10:04 PM
  2. 1995 Pontiac Grand Prix v6 help!
    By brokenmercy in forum General Tech Discussion
    Last Post: 06-23-2010, 03:13 PM
  3. 1995 Grand Prix
    By AML in forum General Tech Discussion
    Last Post: 12-10-2009, 10:06 AM
  4. 1995 Grand Prix - non A/C Serpentine Belt possible?
    By cybersurfer in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-14-2009, 05:24 PM
  5. 1995 Grand Prix SE
    By VGPGT in forum Off Topic Discussion
    Last Post: 04-13-2009, 06:32 PM
