ok, so, just recently(about 3-4 mo. ago) I installed a set of NAPA front wheel hub assy.and they have been much better than the checker garbage (which died in about two mo.) So far........ until the other day, my ABS light came on with the trac off light, and then I had ABS or trac control until I turn the car off, and back on, then it works. at least most of the time. this just started when it snowed the other day. I've NEVER had this problem with the car before, and I'm wondering if it's the NAPA parts I need to know so I can ge t them waranteed and replaced if so. I checked my connections, and wheel end play, etc. and no problems found. why would it start doing this??? moisture?? contraction from the cold??, my car is a general POS??
Jason
