Thread: Can you replace worn buttons on '06 temperature control/DIC?
Results 1 to 12 of 12
  1. #1 Can you replace worn buttons on '06 temperature control/DIC?
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    I am looking at picking up a 2006 GT, but several of the buttons on the dash are worn completely off. I know that this is a common problem as I've seen some sort of wear on every '04+ Grand Prix that I've looked at.
    Can these buttons be replaced or do I need to buy whole new control unit for the A/C & heat as well as the 5-button DIC?
    Basically, the middle DIC button is worn, so is one of the "heated seat" buttons, and one "set" of the triangles (red up triangle for hotter, blue down triangle for cooler).
    I've searched and search and couldn't find anything about it. It seems a common problem so I am surprised that there isn't SOMETHING for it...
    Thanks!
    Currently driving a 2006 Grand Prix GT - Stock
    2000 GTP was killed by 16 year old - Nov 20, 2010 - It only had 74,000 miles, a ZZP 3" Catted Downpipe, ZZP SS PLOG, FWI, 180* T-Stat, Flipped Dog Bones, GMPP Sway Bars, G2 painted Rotors and Calipers, HUMount, and was Dexcool free!
  2. #2 Re: Can you replace worn buttons on '06 temperature control/DIC?
    Pennsylvania
    You could certainly repaint it by hand with a fine brush
    OR
    You could try Reflective Concepts and see if they'll make you decals.
    or...you know, hit up morad for a decent used module.
  3. #3 Re: Can you replace worn buttons on '06 temperature control/DIC?
    Apr 2008
    Marion, Iowa
    Do you know if the temp control buttons are as easy as the DIC buttons to replace?
    The previous owner must have used nail polish to (very badly) paint them. They are horrible.
    I did send a note off to Reflective Concepts (thanks for the tip there).
    Maybe I'll have to see what Morad charges for them.
  4. #4 Re: Can you replace worn buttons on '06 temperature control/DIC?
    Oct 2013
    Iowa
    I am wondering this also. Can anyone give me some help?
  5. #5 Re: Can you replace worn buttons on '06 temperature control/DIC?
    Akron, Ohio
    Yes and no. Don't you love ambiguous answers. You can take it apart and the buttons come out. Easy to do. The problem is no one sells buttons. Only comes as a complete unit.
    If all the lights work, you can get a used one with good buttons and swap it out.
  6. #6 Re: Can you replace worn buttons on '06 temperature control/DIC?
    Oct 2013
    Iowa
    Hmm.. maybe I'll go to a junkyard sometime soon and see if they have one I could snag the buttons out of. Thanks
  7. #7 Re: Can you replace worn buttons on '06 temperature control/DIC?
    gardner,mass
    Yea my center dic button is worn like most.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  8. #8 Re: Can you replace worn buttons on '06 temperature control/DIC?
    SE Level Member SC06GT's Avatar
    Jun 2016
    I need these button overlays too... just emailed reflective concepts.
  9. #9 Re: Can you replace worn buttons on '06 temperature control/DIC?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    JY..
  10. #10 Re: Can you replace worn buttons on '06 temperature control/DIC?
    Apr 2008
    Marion, Iowa
    Quote Originally Posted by SC06GT View Post
    Let us know what you find out...
  11. #11 Re: Can you replace worn buttons on '06 temperature control/DIC?
    Jun 2016
    They responded and don't carry them. BOB SAGET!
  12. #12 Re: Can you replace worn buttons on '06 temperature control/DIC?
    May 2016
    MN
    Junk Yard..
  1. How can I replace control arm bushings?
    By marwan in forum Brakes/Suspension/Chassis
    Last Post: 10-02-2021, 05:38 AM
  2. Replace Auto A/C Control (CJ2)?
    By Joe942 in forum General Tech Discussion
    Last Post: 10-17-2010, 09:00 PM
  3. which worn parts to replace at almost 90k miles?
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2010, 11:30 AM
  4. Tie rods/ Lower Control Arms - replace them all?
    By 86Sierra in forum Brakes/Suspension/Chassis
    Last Post: 10-24-2009, 10:04 PM
