Thread: No up function on window
Results 1 to 6 of 6
  1. #1 No up function on window
    SE Level Member leetaylor's Avatar
    Nov 2010
    Belmont/Charlotte Area.
    I have a 1999 GTP Coupe, So I go to put my window down to let some fresh air in while parked. Let the window down half way, when i went to raise it it did fine but a small amount of mysterious smoke came from the area of the window buttons. made me nervous so I released the button waited a minute and tried again. The window went right back in place like nothing happened.
    Fast-Forward 2 hours. I get out of restaurant, roll window down half way again to drive in town. When I go to put the window back up it doesn't budge. The window would go down even more but not back up. After fiddling with it: pushing down on window as pushing the "up" function, wiggling window with and without pressing button. 2 people pulling up on glass while pressing button the Glass would not budge. and is now stuck 2/3 down. No matter how hard I try the glass won't move
    Any ideas or suggestions? I have no idea where to start. (probably where the smoke came from...)
    Note: just got the car has 108K on it and has been sitting up for little under 1.5 year. and just had a major service.
  2. #2 Re: No up function on window
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    I just had the same thing happen in mine. You can run jumper wires to move the window up(im still doing this lmao), But the switch is bad. There about 100 bucks aswell. If you need to get the window up in a hurry I could take pics of how to jump it so it rolls up
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: No up function on window
    Charles City, IA
    Yeah you need a window switch.
    SMGPFC Two Nipple General
  4. #4 Re: No up function on window
    SE Level Member RideMr2's Avatar
    Memphis
    When I had a 99gtp, same trouble.
    Pop the plastic button off, and you can get a small screwdriver in there.
    I used a spare ignition key to roll the window up and down, until I could get another switch.
  5. #5 Re: No up function on window
    get one from a wrecker for cheap.
  6. #6 Re: No up function on window
    Nov 2010
    Yep that was the problem. Fixed for $84
  1. Wiper Pulse board or Multi function control
    By JGN in forum General Tech Discussion
    Last Post: 06-09-2010, 02:55 PM
  2. Multi Function Switch
    By N8Dogg98 in forum General Tech Discussion
    Last Post: 09-30-2009, 02:48 AM
  3. Vacume barb for keeping pcv function
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2009, 06:43 PM
  4. Broken function
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 01-07-2008, 01:14 AM
  5. The Search Function Works!!! OMG!
    By Lawngoose in forum Off Topic Discussion
    Last Post: 12-27-2007, 11:07 PM
