I have a 97 grand prix gt that will not start. It turns over fine. I have checked the fuel pump and don't have any power. I have checked all fuses and they are good, and replaced the fuel pump relay. I have pulled a plug and no power there either. While reading in a GM repair manual, it said to check the wires behind the fuse block under the hood with a test light, by checking between ground and the one of the wires to the fuel pump relay. When the key is turned on the test light should come on for 2 seconds. It did not. I also noticed I have no dash lights or head lights when the key is turned to on. I suspect the PCM is bad not allowing power out to where it needs to go but I am not sure. Any help would be appreciated.
