Thread: Loud obnoxious whine from supercharger
Results 1 to 20 of 20
  1. #1 Loud obnoxious whine from supercharger
    Jul 2010
    Outside ATL
    99 GTP
    3.4 pulley and supporting mods
    Just recently, expecially on cold morning startups my supercharger has got this growly whine-not the good kind. Kinda sounds like when your power steering pump is going. I probably need a new coupler eventually, but i dont think this is the problem. Its getting worse, i checked the supercharger oil and its a bit low. Could it be my bearings going out or what. Please help, im thinking about pulling the belt off till if fix the problem. Damn, no boost is going to kill me
    THANKS
  2. #2 Re: Loud obnoxious wine from supercharger
    so you have a intake on the car right??
    does it sound like the a shovel being dragged acrss the ground??
    if so thats normal
  3. #3 Re: Loud obnoxious whine from supercharger
    Jul 2010
    Outside ATL
    its not my intake, its a whine coming from supercharger. No scraping or clanking. I know what a bad coupler sounds like and the whine is louder than my intake now. You would think whine would be good, but this is so not good sounding.
  4. #4 Re: Loud obnoxious whine from supercharger
    Jul 2010
    Outside ATL
    any body know whats up with this obnoxious whine, its getting worse
  5. #5 Re: Loud obnoxious whine from supercharger
    West Side Michigan
    Does it sound like this?
    YouTube - Weird engine noise.
    That's mine.. I think the Needle bearings in the S/C are bad. Found out when I got the car that the oil has never been changed.
  6. #6 Re: Loud obnoxious whine from supercharger
    ^^MAFAKIN RIOT!! YOUR SIGNATURE LMAO!!!
    Awesome.
    Anywho...I voted needle bearings a long time ago on Nawar's car...I bet that's your issue.
  7. #7 Re: Loud obnoxious whine from supercharger
    Jul 2010
    Outside ATL
    Quote Originally Posted by nawarkk View Post
    No, that sounds more grinding in nature. Mine is more like a louder whine, really obnoxious like power steering goin bad coming from supercharger.
  8. #8 Re: Loud obnoxious whine from supercharger
    have you for sure isolated it to the blower? taking the belt off makes the sound stop?
  9. #9 Re: Loud obnoxious whine from supercharger
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Does it sound more like this???
    YouTube - scream of death?
    Thats the noise i recently just started getting and its a once i a while thing. Ive been searching and reading all over the place and many are saying it could be a blocked PCV Valve or something but definitely pcv related.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  10. #10 Re: Loud obnoxious whine from supercharger
    So replace the PCV valve? wtf?
    Thread is also kinda old.........
  11. #11 Re: Loud obnoxious whine from supercharger
    Bowie, MD
    You think it could be the pcv valve??
  12. #12 Re: Loud obnoxious whine from supercharger
    Well first step is to take the blower belt off and see if it goes away.
    If people say it could be the PCV then take the valve out and shake it. If it rattles its prolly good.
  13. #13 Re: Loud obnoxious whine from supercharger
    Idaho
    so did the beast ever find the exact issue?I have the same problem.
  14. #14 Re: Loud obnoxious whine from supercharger
    I recently had this issue and thought it was a million other things before I bought a new PCV valve or if you installed a VC breather...my noise went away.
  15. #15 Re: Loud obnoxious whine from supercharger
    Idaho
    I did remove the belt and the whine went away.The whine sounds like its coming from the pulley on the blower.I will change out the pcv, cheap enough.I contacted magneson about a rebuilt snout and they dont have any available.Any hep will be appreciated.Thanks
  16. #16 Re: Loud obnoxious whine from supercharger
    zzp has lots of rebuilt stuff for our cars.
    its very expensive though.
    are you sure it has fluid?
  17. #17 Re: Loud obnoxious whine from supercharger
    I'd NEVER spend that kind of money on an M90 snout...evah
  18. #18 Re: Loud obnoxious whine from supercharger
    hydralic press + get the parts yourself and you're in business.
  19. #19 Re: Loud obnoxious whine from supercharger
    Oct 2008
    Calgary, Alberta
    Did you replace the supercharger belt when you replaced the pulley?
    667 - GTP/GS/SS supercharged with stock 3.8" pulley (67 1/4" -1708mm)
    658 - GTP/GS/SS supercharged with 3.2 - 3.5" pulley (66 3/8" - 1687mm)
    difference in length ( 7/8" - 21mm )
    With an old belt, the extra slack + reduced contact on the s/c pulley the belt could easily be slipping on cold startup. Just want to confirm it is not the belt before throwing money at the snout.
    (I have a newer oem belt on a 3.5" and it will occationally squeak at startup.)
  20. #20 Re: Loud obnoxious whine from supercharger
    Idaho
    The belt is new as of two months ago.Its a Gates belt. The pulley is stock and I have not replaced the pulley.I did change the oil in the blower as soon as this noise began and yes there was oil in it.Smells horrible, new or old.Dont get any on you,it stays with you all day. If rebuilding the snout is possible myself does anyone have a source for the parts?I do have a press and a fair amount of ability But my alldata just covers blower replacement not rebuild.
  1. super loud regal gs, supercharger maybe?
    By e6600 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2010, 07:50 AM
  2. How loud is the glasspack?
    By Black18Ice in forum General Tech Discussion
    Last Post: 10-05-2009, 12:26 PM
  3. Wine?
    By Billyboi6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 08:57 AM
  4. Loud Raido
    By Bruteforce72 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2009, 01:08 AM
