Thread: Ported throttle body
Results 1 to 20 of 21
  1. #1 Ported throttle body
    SE Level Member Vlad0691's Avatar
    Dacula, GA
    How hard would it be to port your own throttle body? Like if you use a Dremel tool and do it?
  2. #2 Re: Ported throttle body
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    Quote Originally Posted by Vlad0691 View Post
    Yeah you can port with just a rotatory tool.
    Just word of advice:
    Just bring down the lip and blend it into the rest of the mouth of the throttle body.
    Don't touch anything around the throttle blade, you'll screw up your idle. So don't increase the diameter of the throttle body.
    Just make sure you take off a little at a time and make as smooth as possible (evenly taking away metal)
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  3. #3 Re: Ported throttle body
    Dacula, GA
    So when I port ONLY grind down that lip on the side to make it a perfect straight-through pipe?
  4. #4 Re: Ported throttle body
    yes. take out the MAF hump and smooth everything out. do not grind down near the throttle plate because it wont seal anymore.
  5. #5 Re: Ported throttle body
    Dacula, GA
    Okay, thanks. What exactly is the MAF hump there for anyway? Just another random GM genius? haha.
    And what else will it do performance-wise other than increase throttle response.
    CAI, 180* T-Stat, SD Headers, EGR Delete
    I have hazy headlights <3.
    R.I.P.
  6. #6 Re: Ported throttle body
    Hey guys...car in avatar...is his car. Your TB is drive by wire...only thing I would do is smooth it out with some different grits of sandpaper if you must...there are no gains to be had from a '04+ TB...plus, your no where near the mod level to be needing that done. Get the HV3 mang...if you want to port something...port the lower intake manifold runners and gasket match them to the intake gaskets.
  7. #7 Re: Ported throttle body
    Dacula, GA
    So porting out my '04 won't increase throttle response?
    And the HV3 insert or headers I'm ordering this weekend. Don't know which yet.
    R.I.P.
  8. #8 Re: Ported throttle body
    oof, im dumb. my bad, dude. yeah, no gains to be had with any throttle body work. leave it alone.
  9. #9 Re: Ported throttle body
    Dacula, GA
    Well okay then, thanks. And I'm ordering headers tomorrow. Chicka chicka yeahhhh
    R.I.P.
  10. #10 Re: Ported throttle body
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Isn't there some kind of electronic mod to increase the throttle respone on that DBW BS? Your really limited by the PCM opening it slowly to manage torque... At least thats how it is on my gramps new silverado from what I remember reading. When I borrowed his truck I could punch it to the floor going up a hill and no change. My 98 gmc v6 feels like it has more power than his 5.3 with over 100HP more.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  11. #11 Re: Ported throttle body
    Probably a tune would fix it...my Cobalt is DBW, and I smoothed the intake runners on the manifold and polished both inlet and outlet of the throttle body with some different grit sandpaper...and considering the car is pretty underpowered...I DID notice a little better throttle response...not sure how it would work on your car though.
  12. #12 Re: Ported throttle body
    i had to play with my DBW tables on my subbie to get the car to be more driveable. it helped out a lot for how it drives.
  13. #13 Re: Ported throttle body
    I bet I would care about them a TON more if my balt was a 5-spd...but its not. Lame.
  14. #14 Re: Ported throttle body
    i actually had to REDUCE the throttle response because it was commandling like 30% throttle almost immediately when i touched the pedal. made it very hard to take off from a stop without revving the crap out of the motor. now that i backed it off and made the throttle mapping more linear its a dream in comparison to how i bought it.
  15. #15 Re: Ported throttle body
    Charles City, IA
    hptuners cant adjust the dbw tables, looked for them on my bosses truck.
    SMGPFC Two Nipple General
  16. #16 Re: Ported throttle body
    GT Level Member rmcardle3's Avatar
    Houston, TX
    I am preparing for the L67 (Gen3) to Gen 5 swap. I just recieved my Gen 5 M90. I am trying to make sure I have everything I need for a smooth swap.
    Can someone please remind me why I am worried about using my 2000 L67 Throttle Body/TPS/MAF.
    (Besides the fact that I want to port my TB, LIM and M90).
    There has got to be a reason it won't just bolt and go, right?
    2000 GRAND PRIX GTP (Sedan)
    MICHELIN Pilot® Sport A/S Plus 245/50 ZR16 97W M+S
    Cone Intake, SD Headers
  17. #17 Re: Ported throttle body
    Charles City, IA
    You need an adapter.
  18. #18 Re: Ported throttle body
    Houston, TX
    Yes, thank you!
    Gen 5 to L67: = It's like $75.00 @ ZZP right?
    (But this is the lame alternative, because it uses the lame stock TB, right?)
    Gen5 to LS1/LQ4: = This is the reason I can't get my parts list together.
    (It's like a kazillion dollars for this one because of the Adapter/ TB /MAF, right? + Import the LQ4 MAF Table right?)
    Sorry for the drama, just trying to keep it straight in my head.
  19. #19 Re: Ported throttle body
    Minnesota
    Sorry to thread jack and bring an oldie back but I am looking to upgrade my tb this spring and probly just going to bring mine to a machine shop while my car is torn apart for porting my blower. So is getting rid of that maf hump the best way to go i take it? is it worth doing even?
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  20. #20 Re: Ported throttle body
    You can...but you will need a MAF tune to fully benefit from porting the stocker.
  1. Ported throttle body choice
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2009, 12:14 PM
  2. Ported and Painted Throttle Body
    By GTP SE in forum Visual/Body Modifications
    Last Post: 01-04-2008, 01:38 PM
