Thread: What's the best coolant flush method?
Results 1 to 5 of 5
  1. #1 What's the best coolant flush method?
    SE Level Member dl1027's Avatar
    California
    I have a Prestone flushing kit that backflushes with the water hose. I have tried some cleaners bought at AZ. I tried the Bobs the Oil guy dishwashing detergent method too but nothing can remove the dexcool sludge that is in the radiator and the rest of the cooling system. I'm getting a new radiator but want to clean the entire system before using the new radiator. Is there a product out there that will clean all the sludge out first try?
  2. #2 Re: What's the best coolant flush method?
    GTX Level Member cerick08GP's Avatar
    On BITOG “they” recommend dishwasher detergent. NOT dishwashing detergent. There is a big difference.
    About the only method to get Dex out, is multiple drain and refills of the coolant. Just use plain (or DI if you like) water to fill it up. Drive it for a day, then repeat like 4 times. Then drain and use what ever coolant you had in mind. GL
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  3. #3 Re: What's the best coolant flush method?
    Charles City, IA
    Wynns radiator flush kit and a power flusher at a shop.
    SMGPFC Two Nipple General
  4. #4 Re: What's the best coolant flush method?
    Colorado
    do you put the flush kit in the top heater hose into the firewall
  5. #5 Re: What's the best coolant flush method?
    HUDSON
    He's right,
    drain, fill with water, drive a day,...repeat.
    To drain mine, all I did was use a long clear vynil hose pushed to the bottom of the radiator thought the cap opening, then siphon into empty jug (gallon or bigger).
  1. Coolant Flush?
    By gahris in forum General Tech Discussion
    Last Post: 04-03-2010, 02:12 PM
  2. Coolant Flush twice?
    By nyydmb12 in forum 04+ Specifics
    Last Post: 02-14-2010, 08:17 PM
  3. attempting coolant flush
    By Nodoz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2009, 05:30 PM
  4. Going to vip for a coolant flush
    Last Post: 03-12-2008, 03:42 AM
  5. Coolant Flush : How to?
    By 04CompG in forum General Tech Discussion
    Last Post: 03-09-2008, 08:35 AM
