Thread: Car is shaking
Results 1 to 9 of 9
  1. #1 Car is shaking
    SE Level Member Warlord55's Avatar
    Jun 2010
    Nebraska
    My car(2002 GP SE) always shook a bit at around 70-75mph. Yesterday I was driving at night and I hit something in the road with my left tires, it looked like a sheet of metal or something flat. Anyway after that it started to shake even more at 55-75 about 3 times as bad. It also get worse when slowing down and turning right. I looked at the tires the rims and anything else I could think of, but I couldn't see anything wrong with it, I also had someone look at the tires when driving and they look fine.
    I don't want to take it to a shop and get charged with something I could fix.
    Anyone have any clue on what this could be?
  2. #2 Re: Car is shaking
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    Since you say it always shook around 70-75 you can start with getting your wheels balanced. Then take it from there
  3. #3 Re: Car is shaking
    Jun 2010
    Nebraska
    So do you think that hitting that thing in the road might of "unbalanced" the tires even more?
  4. #4 Re: Car is shaking
    Jul 2008
    sumter,south carolina
    feel for bubbles on the inner sidewall.
    02 GTP with mods 05 GP for DD
  5. #5 Re: Car is shaking
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    Check your:
    Tire pressures
    Lug Nuts
    Motor Mounts
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  6. #6 Re: Car is shaking
    Kansas
    Check the hubs also.
    SOLD 1999 GT Silvermist TS
  7. #7 Re: Car is shaking
    Donating Users squeaks130's Avatar
    Fargo, ND
    Balancing would be the first thing I would try, when your car hit the metal it coulda knocked a wheel weight off. Re balancing usually isn't too much, and its something that you cant do yourself.
    00 GT- Tint, Pre-gens, Hopes and Dreams
    91 F-150 4.9L, Pipes, tint, 2 inch lift, and 35's
    Little boys wear bow ties. Big boys drive FORD
  8. #8 Re: Car is shaking
    GTP Level Member SuperSport's Avatar
    Michigan
    Quote Originally Posted by squeaks130 View Post
    Was just going to suggest this.
    Make sure your wheelweights are still there...
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  9. #9 Re: Car is shaking
    Jun 2010
    Nebraska
    Well I went to get my tires balanced. When they looked at them they saw that two of the tires are starting to separate. So I had all the tires balanced and had them put the bad two in the back, since the tires only have 20k miles on them. The shaking basically stopped and I'll just get new ones when it gets worse.
    Thanks for all the input.
  1. strange shaking
    By occrocks in forum General Tech Discussion
    Last Post: 12-18-2010, 01:19 PM
  2. 02 GTP shaking
    By y2ed in forum General Tech Discussion
    Last Post: 09-27-2010, 03:19 PM
  3. shaking...
    By Couch in forum General Tech Discussion
    Last Post: 07-09-2009, 10:25 PM
  4. Car shaking
    By Davisgtp in forum General Tech Discussion
    Last Post: 05-30-2009, 12:51 AM
  5. shaking when i let off brake
    By 2000GTP in forum General Tech Discussion
    Last Post: 10-07-2008, 06:49 AM
