Does anyone know who sells crank keys for the 3800, mines stripped. Also somewhere that sells the bottom sprocket for the timing chain? ZZP and morad both came up with no results. If you have either, please pm me.
The crank sprocket can be found on rockauto.com. $30 for Cloyes or $51 for Sealed Power. I couldn't find the crank key anywhere, but is it a standard size that you could buy a length of and cut the size piece that you need?
you might be able to find some peices of steal at your local hardware store and just cut it to length or try your local lawnmower repair shop. they might have something close to what you need. nothing a grinder can't fix
When i bought a new balancer it came with a crank key.
