Thread: thermostat housing bolts stripping my sockets..help!!!
Results 1 to 13 of 13
  1. #1 thermostat housing bolts stripping my sockets..help!!!
    Florida
    Im trying to upgrade my stock thermostat to a 180* and im having a difficult time getting these simple bolts off the housing.Its the 2 main bolts obviously,anybody have any idea or tips on to get them off? So far I have stripped 3 of my 10mm sockets and its annoyin
  2. #2 Re: thermostat housing bolts stripping my sockets..help!!!
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    Buy better sockets. ive seen bolt heads round off never a good socket
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  3. #3 Re: thermostat housing bolts stripping my sockets..help!!!
    Donating Users Rust's Avatar
    Jun 2010
    Canada
    There is definitely something wrong with either the quality of the tools or a major problem with the bolt.
    Get a good socket, soak the bolts for a while, lightly tap them a few dozen times with a brass punch or hardwood block and hammer, and be prepared to possibly replace the bolts.
    Keep soaking with penetrant and keep tapping until the oil and shock free them up. May take a while, even a few days of trying.
  4. #4 Re: thermostat housing bolts stripping my sockets..help!!!
  5. #5 Re: thermostat housing bolts stripping my sockets..help!!!
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    try a 6 point deep well. 10mm is indeed the correct size.
    edit: one of them is like a stud, so you have to use a deep well. you are using deep wells, right?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  6. #6 Re: thermostat housing bolts stripping my sockets..help!!!
    Florida
    Ok.Well the sockets I do have are no craftsman for sure,it was a cheap $35 set from advance auto.So it may be the sockets,ill try and buy some other ones.But I used WD-40 last week while taking a stab but nothin.Ill try these methods though.
  7. #7 Re: thermostat housing bolts stripping my sockets..help!!!
    Florida
    what size socket do you suggest then?As far as I know the directions say 10mm
  8. #8 Re: thermostat housing bolts stripping my sockets..help!!!
    Nov 2008
    Fremont Nebraska
    10mm is right. are you using 12 point or 6 point sockets? are you using regular short sockets, or long ones?
  9. #9 Re: thermostat housing bolts stripping my sockets..help!!!
    if the bolt is fine and your socket is ****ed.... you REALLY need better sockets.
    I know i bought cheap ones (207 piece for $135 anyone?), but they're holding up just fine so far.
  10. #10 Re: thermostat housing bolts stripping my sockets..help!!!
    Florida
    yeah the problem may be my socket size.Im not using deep well ones only the short small ones.And im using 6point-my ratchet.Ill try again soon,this is a simple task that has turned my day into a mess lol
  11. #11 Re: thermostat housing bolts stripping my sockets..help!!!
    Jul 2008
    sumter,south carolina
    i wasted money on that autozone el cheapo set... i broke several sockets in the first week.
    go buy a kobalt deep well 12 point socket.. that should snatch it off for ya.
    02 GTP with mods 05 GP for DD
  12. #12 Re: thermostat housing bolts stripping my sockets..help!!!
    Florida
    aight,thanks man
  13. #13 Re: thermostat housing bolts stripping my sockets..help!!!
    Charles City, IA
    Just buy the craftsman 200 piece set that they always have on sale for 180.
    SMGPFC Two Nipple General
  1. Thermostat housing sealant?
    By GTPRiley in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2011, 01:02 AM
  2. Weather Stripping
    By stein2000GTP in forum Visual/Body Modifications
    Last Post: 07-30-2011, 05:30 AM
  3. Replies: 8
    Last Post: 10-05-2010, 08:57 PM
