Thread: Tranny fluid disappearing?
Results 1 to 8 of 8
  1. #1 Tranny fluid disappearing?
    Mesa, Arizona
    1994 3.1 Automatic tranny 4 speed
    Using tranny fluid. No leaks under car (not when just sitting and running anyway).
    Where else can tranny fluid go?
    Thx
  2. #2 Re: Tranny fluid disappearing?
    check your radiator, the trans cooler may be leaking.
  3. #3 Re: Tranny fluid disappearing?
    Mesa, Arizona
    Radiator checked, looks ok. Do I have a vacuum modulator on that tranny?
  4. #4 Re: Tranny fluid disappearing?
    You should. rignt on the front driverside. Pull the vacuum line and check for fluid in it.
  5. #5 Re: Tranny fluid disappearing?
    Mesa, Arizona
    I pulled the line and there is no fluid in it. No fluid in the radiator, no fluid under the car,...is it coming out while I'm driving?
  6. #6 Re: Tranny fluid disappearing?
    It's kinda tough to diagnose a leak while driving from here. You are about 3,000 miles away and it's tough to see if the subframe and underside of the car is wet. Know what I mean? You need to do some looking and investigating to help us out here. You are our eyes, ears and hands.
  7. #7 Re: Tranny fluid disappearing?
    SE Level Member Whiplash Performance's Avatar
    Hillsborough, NJ
    To find transmission leaks you'll need to drive around then park it and check all the lines. The lines are under a lot of pressure and the leaks only appear when pressurized.
    Whiplash Intense Performance Hillsborough, NJ
    Performance Parts & accessories| Powder Coating | Engineering
    Intensewhiplash.com
  8. #8 Re: Tranny fluid disappearing?
    The lines should be wet if leaking. Running or not, if it's leaking enough to notice on the dipstick then it should be visible.
  1. Synthetic Tranny Fluid
    By mikesarebetter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2009, 09:01 PM
  2. 98 GTP leaking tranny fluid
    By millfire517 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2009, 11:02 AM
  3. Help!! Tranny leaking fluid
    By NMillis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 06:48 AM
  4. What Tranny Fluid should I run?
    By Iron Indian in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-15-2009, 01:24 PM
  5. Replacing Tranny and S/C fluid.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-20-2008, 07:31 AM
