Thread: Changed Tranny Fluid/Filter, Fuel Filter Tonight
Results 1 to 6 of 6
  1. #1 Changed Tranny Fluid/Filter, Fuel Filter Tonight
    GT Level Member nickbuol's Avatar
    Apr 2008
    Marion, Iowa
    Both jobs were pretty easy. I was surprised how BAD the transmission fluid was. No chunks, but lots of gray fluid came out of the filter. Below is an approximation of what the new color was vs. what was in there that I removed. It was almost 100% gray with just a touch of pink. 73,000 miles on a 2000 GTP. First tranny fluid change so I wanted to do the filter too. Never did a pan drop, filter change before. It wasn't too bad at all. Hardest part was getting that stupid o-ring out where the filter went in.
    Then I changed out the fuel filter. Been meaning to do that forever too. Another super easy job. Glad it is done.
    Now this weekend I get (yeah) to change out my driver side rear wheel bearing. :-( I've replaced the front passenger already (failed in 8 weeks - Thanks ZZP so I guess I've actually done it twice), the passenger rear failed this past spring and I was in a bind and had to pay $350 to get it fixed. This time I am getting a Timken from RockAuto for about $90 shipped to my door. :-)
    Fun fun... I would have rather used the money I spent to do my last wish list items (plugs, pulley, PCM, belts), but that's OK. At least I saved several hundred over having to pay someone else to do all of this work.
    It is because of THIS site that I have been able to do so much with my 2000 GTP. Thanks for everyone that posts here or helps to keep this site up and running.
    Transmission fluid (new on left, my used on the right)
    Currently driving a 2006 Grand Prix GT - Stock
    2000 GTP was killed by 16 year old - Nov 20, 2010 - It only had 74,000 miles, a ZZP 3" Catted Downpipe, ZZP SS PLOG, FWI, 180* T-Stat, Flipped Dog Bones, GMPP Sway Bars, G2 painted Rotors and Calipers, HUMount, and was Dexcool free!
  2. #2 Re: Changed Tranny Fluid/Filter, Fuel Filter Tonight
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Did it smell burnt? Have a gritty feel to the fluid?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Changed Tranny Fluid/Filter, Fuel Filter Tonight
    Apr 2008
    Marion, Iowa
    Nope. Didn't smell burnt or feel gritty. It was quite slick actually. Way slicker and "smooth" feeling than synthetic engine oil after 3000 miles. I was just surprised at the color.
  4. #4 Re: Changed Tranny Fluid/Filter, Fuel Filter Tonight
    Brewcity, WI
    73k is kinda long... seeing how u have a GTP and I'm sure you get on it often. But as long as there weren't chunks and shavings, think your in the clear.
    and I thought mine was bad, 126K (60K on fluid) (http://i162.photobucket.com/albums/t...0/IMG_0139.jpg
    Self-denied SMGPFC member #1
    SEARCH works!
  5. #5 Re: Changed Tranny Fluid/Filter, Fuel Filter Tonight
    Apr 2008
    Marion, Iowa
    Yeah, mine was definitely more gray than that. I should have taken a picture... Not a single chunk or shaving in there though, and I was not experiencing any lags or slips, so I think that I am OK. Tomorrow is the rear wheel bearing. Yeah! Bring it on!
  6. #6 Re: Changed Tranny Fluid/Filter, Fuel Filter Tonight
    Charles City, IA
    Gray means moisture was in it.
    SMGPFC Two Nipple General
  1. changing fluid and filter in tranny???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 07-23-2012, 06:06 AM
  2. Hardshifting after new fluid and filter change.
    By Pontiacman76 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-06-2010, 05:47 PM
  3. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  4. Tranny fluid and filter change
    By chevyy1212 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2010, 03:49 PM
  5. Tranny Filter Gasket
    By SDGTP99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-13-2009, 03:41 AM
