Thread: Low Coolant Indicator
Results 1 to 8 of 8
  1. #1 Low Coolant Indicator
    El Cajon
    I can't get my Low Coolant Light to go out. I filled the coolant overflow tank and that didn't work. Is there a way to bleed the air out of the system if it has any? I need help!!!!!!!!!!
  2. #2 Re: Low Coolant Indicator
    Charles City, IA
    Let the car warm up to operating temp and open the 7mm bleeder on the t-stat assuming you have a 3800 engine. If you have a 3.1/3.4 there are two bleeds one by the t-stat neck and the other is by the water pump they are both 7mm. More than likely your sensor has crap in it, you can clean it out or just unplug it it is on the top right of the rad.
    SMGPFC Two Nipple General
  3. #3 Re: Low Coolant Indicator
    pay attention to where youre posting!!! jeebus almighty!!
    moving...
  4. #4 Re: Low Coolant Indicator
    Willoughby, Ohio
    if bleeding the system doent help, your sensor probably went bad, if you watch your temp guage you can just unplug it the sensor, if you dont watch your guages replace the sensor
  5. #5 Re: Low Coolant Indicator
    Charles City, IA
    Quote Originally Posted by CTKGP09 View Post
    If he does not watch the gauges he wont see the light.
  6. #6 Re: Low Coolant Indicator
    Willoughby, Ohio
    i mean im giving the benifit of the doubt by sayin he will notice the DUMMY light pop up!
  7. #7 Re: Low Coolant Indicator
    SE Level Member dl1027's Avatar
    California
    On a GP GT, where is the sensor located? Thanks
  8. #8 Re: Low Coolant Indicator
    GTP Level Member SuperSport's Avatar
    Michigan
    Passenger side towards the top of the rad. Youll see the square sensor with the plug on it.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  1. Gear Indicator on 99 gt
    By bigboibbp in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2009, 11:38 AM
  2. Oil change light indicator
    By sasquatch094 in forum General Tech Discussion
    Last Post: 09-06-2009, 09:20 AM
  3. tcs off indicator and ABS indicator both on - why??
    By RealtyCaffeine in forum General Tech Discussion
    Last Post: 08-13-2009, 06:17 PM
  4. Gas Indicator issue
    By sassygtchick in forum General Tech Discussion
    Last Post: 06-15-2009, 02:12 PM
  5. boost indicator on DIC
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-19-2008, 10:17 AM
