Thread: draining coolent
Results 1 to 14 of 14
  1. #1 draining coolent
    GT Level Member fremmy182's Avatar
    Center Moriches, New York
    I want to drain my radiator for my 2000 pontiac but i cant find a drain plug. Im sure there has to be an easy way to do it but i just cant seem to figure it out.
  2. #2 Re: draining coolent
    Charles City, IA
    pull the lower hose.
    SMGPFC Two Nipple General
  3. #3 Re: draining coolent
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    the plug is on the drivers side bottom of the radiator. most times they don't want to budge so just pull the lower radiator hose.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  4. #4 Re: draining coolent
    SE Level Member Paul79UF's Avatar
    Florida
    I've read that sometimes removing the plug can cause it to leak in the future.
    So just stick to taking off the lower hose like the guys above recommended.
    I was forced to change my coolant when the hose going to the overflow tank was severed by the belt. Now I have it zip tied out of the way to the battery handle.
  5. #5 Re: draining coolent
    i dont really get where the lower hose is.. When im under the car is it going to be the hose closest to me?
  6. #6 Re: draining coolent
    Charles City, IA
    What are you trying to do? If you can not figure out what the lower hose is you may want to have some one assist you.
  7. #7 Re: draining coolent
    Bonaire 31005
    There is a hose going into the top of the radiator. there is another hosegoing to the bottom of the radiator. Pull the bottom one. If you were under the car it will be the one closest to you. Don't forget to bleed the system after you fill it back up by opening the screw on top of the thermostat housing by where the radiator goes into the top of the engine.
  8. #8 Re: draining coolent
    what do you mean by bleed it.. and i drained all the anti freeze but i cant get the hose back on, so im waiting for someone to assist me because it would be a lot easier with two people.
  9. #9 Re: draining coolent
    Bonaire 31005
    You have to bleed the air out of the coolant system after your done filling it up. Some people have a crap load of trouble with their car over heating after they fill it up and some don't have any issues.
    Just fill the radiator all the way up with the car off. squeez the top radiator hose to attempt to get more air out. Refill. Repeat. start car. While car is still running refill radiator. Put radiator cap back on befre you stop the car. Let run and make sure it does not over heat.
  10. #10 Re: draining coolent
    Charles City, IA
    Quote Originally Posted by FastestGTP View Post
    Or just open up the bleed screw on the t stat housing as you will it up, then start it and let it reach operating temp with the rad cap off and wait for coolant to come out the bleeder.
  11. #11 Re: draining coolent
    alrightt thanks, now i was wondering if theres anyway i can put a hose to it and flush the whole thing because theres so much goo and stuff everywhere.
  12. #12 Re: draining coolent
    Charles City, IA
    You can buy flushing tees at autozone, or take it to a shop with a power flusher.
  13. #13 Re: draining coolent
    i cant just put the hose on the thermostat and just flush it out?
  14. #14 Re: draining coolent
    Michigan
    the flushing tee allows you to flush it for a mere 5 bucks or something, and it does it the right way. go that route.
    or fill your radiator with water, let it run a few minutes, drain, and repeat as you see necessary.
    97 GT - slow, rusty
  1. Strawberry milkshake coolent
    By Machzzzz1 in forum General Tech Discussion
    Last Post: 09-07-2010, 04:27 PM
  2. Draining coolant..
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2010, 01:36 AM
  3. 2000 Grand Prix Gt draining battery
    By Kranium31 in forum General Tech Discussion
    Last Post: 01-22-2010, 07:42 PM
  4. leaking coolent please help
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-19-2009, 12:40 PM
  5. Draining Coolant Completely
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2008, 10:55 AM
