Thread: how do i remove the balance shaft
Results 1 to 11 of 11
  1. #1 how do i remove the balance shaft
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    rebuilding my motor next month and have been told that this part can go..anyone know how (pics are prefered) to remove this and block the oil passages to it? also is this really advisable?
  2. #2 Re: how do i remove the balance shaft
    Charles City, IA
    just take off the gear that drives it then let it sit in there, then you do not have to worry about blocking the oil holes.
    SMGPFC Two Nipple General
  3. #3 Re: how do i remove the balance shaft
    Bonaire 31005
    Thats the easiest way to do it.
  4. #4 Re: how do i remove the balance shaft
    Feb 2010
    somewhere cold
    i searched a little harder and did find a writeup on blocking the hole so ill probebly try it but again is it adviseable to remove the balancer? are there any drawbacks?
  5. #5 Re: how do i remove the balance shaft
  6. #6 Re: how do i remove the balance shaft
    The most correct way to block off the holes and remove the balancer require an engine rebuild. This is because you'd drill and tap the oil holes.
    Next best method is to remove the gear (like you'd do for a double roller timing chain) and leave the balancer in place. This essentially stops you from having a balancer bearing issue and removes it from the drive of the cam gear.
  7. #7 Re: how do i remove the balance shaft
    no real reason to remove it.
    That...I disagree with ya jeeves...because its rotating mass...and any sort of rotating mass I'd love to get rid of especially if your building a motor from the ground up or doing a double roller install the right way...in the DSM world they came to to figure that for every pound removed from the rotating assembly you can gain, on average, 2.7 crank HP. And you were the one who wondered why my motor revved so fast...plus...mine is balanced...that might help too.
    This. When it comes to anything internal I'd rather do it right the first time then half ass it.
  8. #8 Re: how do i remove the balance shaft
    Feb 2010
    somewhere cold
    then consider it removed..thanks guys
  9. #9 Re: how do i remove the balance shaft
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Also heard of people pressing a cam bearing(think from some kind of oldschool dodge) in there upside down so the oil hole is on the opposite side(wrong side) so it blocks the passage with no drilling and tapping. Don't know if it was these cars but heard that a copper pipe cap can be pressed in as well. If it was me I would either use the bearing or make sure I pinned the plug. Just hate the idea of introducing metal shavings into the oil passages...
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  10. #10 Re: how do i remove the balance shaft
    I've had a lot of guys install double rollers and not rebuild. Therefore it's simply a case of removing the balancer gear. It's no longer rotating mass at that point, it's dead weight. Not ideal, but unless you are rebuilding and flushing everything out...it's the best of the available.
    Blue.. my engine revved extremely fast. Balancer was still in place. I reduced weight in the retainers and rockers.
  11. #11 Re: how do i remove the balance shaft
    Feb 2010
    Oklahoma City, OK
    And thats^^ what I did on my truck when I replaced the timing chain on it last month. Put a couple hundred miles on it already and no problems and noticed no more vibration than before...
  1. balance shaft removal PLZ HELP
    By bigdawg15005 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2009, 11:58 AM
  2. Sealing off balance shaft oil hole.
    By chico in forum How To Write-Ups/Tech Tips
    Last Post: 08-09-2009, 11:22 PM
  3. Cam Shaft Sensor
    By cmdeasy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2009, 03:51 AM
  4. Balance Shaft
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2008, 10:42 PM
  5. CV Shaft
    By webracin in forum Shops and Community Heroes
    Last Post: 04-15-2008, 01:38 AM
