Thread: Thumping noise when braking
Results 1 to 9 of 9
  1. #1 Thumping noise when braking
    Iowa
    Has anyone had a problem like this? When I am going 55-60mph and apply the brakes, there is a thumping noise that is related to wheel speed. I can feel it in the steering wheel and on the brake pedal, and it just feels like its coming from the front end. When I am going slower speeds, say less than 30mph, there isnt any thumping noise unless I am applying the brakes hard. I have looked at the front brake pads/rotors, and everything looks fine. The steering wheel doesn't pulsate back and forth like the rotors are warped, and I have never heard a noise like this before, but I've never owned a front wheel drive car before either. Please point me in the right direction. Thanks!
  2. #2 Re: Thumping noise when braking
    Iowa
    Come on guys....anyone?
  3. #3 Re: Thumping noise when braking
    Donating Users drewprix86's Avatar
    ATX
    mine did the same think. it was almost jurking too. it was the abs sensor on the hub (front wheel)
  4. #4 Re: Thumping noise when braking
    Dec 2008
    philly
    motor mounts, trans mounts?
  5. #5 Re: Thumping noise when braking
    Florida
    Hmmm, could possibly be the motor/trans mount. Mine made a pretty bad thumping noise when braking(1/2 pedal or more) when my bottom motor mount was shot. What it was, is when I hit the brakes, the engine would shake back and forth in the engine bay, causing the noise.
    Simple thing to do is just check all your mounts, especially if they are all stock.
  6. #6 Re: Thumping noise when braking
    Iowa
    thanks....the thumping is pretty rapid, so I'm guessing the motor or trans wouldnt be shaking that bad or the car would fall apart....i'll check the abs sensor thing
  7. #7 Re: Thumping noise when braking
    Topeka, KS
    Could be a warped rotor too. You would feel it in the Pedal though.
  8. #8 Re: Thumping noise when braking
    Iowa
    Well I thought it was going to be a rotor at first too.....its kind of hard to explain the noise/feel of it. Imagine a groove across the rotor, and a similar sized crossways protruding part of the brake pad. When you brake, its like the protrusion is hitting that groove every time the wheel goes around.
  9. #9 Re: Thumping noise when braking
    Iowa
    Fixed it tonight.....after some detail diagnosing, I replaced both rear brake rotors and brake pads, and its great now. It was very deceptive as it felt/sounded like it was coming from the front of the car, but actually was coming from the rear.
  1. Parking Brake Thumping/Stuck On?
    By LuckyBambu in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2010, 09:51 AM
  2. Metallic noise that goes away with braking
    By kind153 in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2010, 03:32 PM
  3. Light Thumping sound under car :S
    By 9ordohz in forum General Tech Discussion
    Last Post: 02-18-2010, 12:47 PM
  4. Grinding when braking?
    Last Post: 02-15-2010, 11:54 AM
  5. thumping noise comming from front end.
    By need2know29340 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-29-2009, 11:06 PM
