Thread: 1inch od m90 bearings?
Results 1 to 7 of 7
  1. #1 1inch od m90 bearings?
    Mn
    I have tried to order them from zz and got the wrong ones along with them not getting back to me to reutrn them. wich sucks. I have also tired super charger tech and they have never heard of them being that big. I made the mistake of thinking that as long as I had it apart that I would replace them and now I cant find them any place? Does anyone have any Idea were I could get them from. Its all I need to get my car going again. Its an 04 gtp comp G. Thanks for any info
  2. #2 Re: 1inch od m90 bearings?
    Mn
    I think I have it figured out. I have bearing like in the svt superchargers called a hole through bearing. They are way more expensive too!
  3. #3 Re: 1inch od m90 bearings?
    GTP Level Member lambokit's Avatar
    Apr 2009
    Radford, Virginia
    You need 2 needle bearings. #FC 65477. Try this
    INA FC65477 ($3.53ea. from ebatmus)
    Google is your friend.
    Lambokit to be built!!!!!
  4. #4 Re: 1inch od m90 bearings?
    Apr 2009
    Radford, Virginia
    Also, I can tell you how to get them out without screwing up your housing. If you havd drill press, 1/8" pipe tap, grease gun and can tap a hole. I can even send you pics. Enjoy...
  5. #5 Re: 1inch od m90 bearings?
    Mn
    I already have the bearings out. They are larger then the normal bearings and there is no cap on the end. I have a set of those that I need to send back. They fall right in the holes and are to small for the shaft on the rotors. I looked up the ones you suggested and they say that they have a cap on the end. Ill give them a call in the morning and see what they say. Thanks for the info! This site is awsome!
  6. #6 Re: 1inch od m90 bearings?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    Quote Originally Posted by lambokit View Post
    i may have the number wrong but i think its a number 11 grease fitting..they are rare but if you get them u can just tap them in with a socket and hammer and u dont need to tap the casing...as i said it may be the wrong number but if u find the size it makes the job that much easier. did it for mine as an experiment as im lazy and it worked great and took all but 2 minutes for both to be removed
  7. #7 Re: 1inch od m90 bearings?
    Mn
    there are no holes on a gen 5 to tap into and the bearings are hole through so there is no end cap for grease to push on. they are the same size bearings as the m112. They are also about 50.00 each wich sucks but o well lesson learned.
  1. hub/bearings/breaks?? Help Please
    By jayson14 in forum General Tech Discussion
    Last Post: 04-10-2011, 05:52 PM
  2. supercharger bearings???
    By colindunn in forum Off Topic Discussion
    Last Post: 06-03-2010, 02:58 PM
  3. Bearings
    By LukesGTP in forum Tires & Wheels
    Last Post: 04-19-2010, 02:57 AM
  4. Tensioner bearings or cat?
    By nanuke in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-18-2009, 08:53 AM
  5. wheel bearings
    By 98GTPCALGARY in forum General Tech Discussion
    Last Post: 06-11-2009, 02:45 AM
