Thread: Leaking roof
Results 1 to 12 of 12
  1. #1 Leaking roof
    SE Level Member Hobbes666's Avatar
    May 2008
    Well after it rained today I noticed that the overhead roof liner was wet. Right around the interior lights. I suspect that the OnStar antennae was not tight to the roof allowing water to leak in. Anyone had this problem before? I was wondering if it would be worth it to just have a bodyshop remove the antennae and patch the roof, or if i should see if they can put a new seal around the antennae. Its a 2004 gp. I dont use the OnStar, however I just got the car and mabey have drivin it 200 kms so far. Anyone else experience this ?
    Thanks
  2. #2 Re: Leaking roof
    May 2008
    is this a car with a sunroof? If it is it could be a clogged drain tube. The way to test it is to take a large cup of water and pour it in the trough at the front of the sunroof. The water should drain out of a tube on either side. If it is clogged, I fixed mine by taking a air pump, for inflating a air bed, and inserted it into the open end and pumped.
  3. #3 Re: Leaking roof
    Odessa, MO
    I have a friend who's wife drives an '04 and had the same issue. Dealership replaced the OnStar antenna, just as you mentioned, and the leak stopped.
  4. #4 Re: Leaking roof
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by rdicarlo View Post
    Where can I find these drain tubes?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  5. #5 Re: Leaking roof
    SE Level Member bentendo92's Avatar
    Aug 2008
    New Hampshire
    Quote Originally Posted by Hobbes666 View Post
    Thanks
    I almost guarantee that it IS the Onstar Antenna. I just took mine to the dealership to have it fixed. I attempted to do it myself but with limited tools and no patience, I figured I would only succeed in breaking the overhead console. I did just that... heh.. Dealer charged 97.00 - a bit pricey IMO but I am glad it stopped leaking plus they did fix what I had broken.. heh.. My cup holders were getting filled every time it rained.
    Mine is also a 2004.
    And a word of advice... if you live where there is a lot of snow/ice in the winter, be really careful when cleaning the car off. I talked to the guy and he said that they aren't held on by a lot and that he sees this often. It usually gets loosened by people not paying attention when they are scraping snow off the car. After he said that, I realized that I can admit to being a bit rough when sweeping the snow off in a rush.
  6. #6 Re: Leaking roof
    Moore, Oklahoma
    Its the Onstar antenna, I promise. I just fixed my GFs brother 04 Comp G with the same damn problem. I pulled out the headliner and had him spray down the car. It leaked at the onstar antenna. I used a little bit of RTV on both sides and sealed it up, hasn't had a problem since.
    Shawn W. Larsen
  7. #7 Re: Leaking roof
    Fairfax, Virginia
    Hi all... new here.
    I'm having the same on-star antenna leak. I want to repair it myself, but don't want to break the reading lamp overhead console. Can anyone give me some more specific directions?
    Thanks,
    Jason
  8. #8 Re: Leaking roof
    Aug 2008
    KCMO
    i would say this needs to go in the recall list for the car so every one with onstar can get this fixed. my mom has an 05 and it leaked so bad is caused her sunroof motor to short out and quite. and i have a buddy with an 05 gxp and hes leaks pretty bad too.
  9. #9 Re: Leaking roof
    Moore, Oklahoma
    A little RTV is all you need to fix it up......
    Shawn W. Larsen
  10. #10 Re: Leaking roof
    CATAWBA, NC
    Does anyone have instructions for removing what is necessary to get at the bottom of the Onstar antenna? I want to fix this myself, but do not want to break anything in the process.
  11. #11 Re: Leaking roof
    SE Level Member ceelo's Avatar
    atlanta
    Gotta remove the headliner
    1. Disable the SIR system. Refer to SIR Disabling and Enabling Zone 2 and to SIR Disabling and Enabling Zone 6. Caution: Do not attempt to repair or alter the head impact energy-absorbing material glued to the headliner or to the garnish trims. If the material is damaged, replace the headliner and/or the garnish trim. Failure to do so could result in personal injury.
    2. Remove the sunshades. Refer to Sunshade Replacement (See: Sun Visor\Service and Repair\Removal and Replacement\Sunshade Replacement) .
    3. Remove the sunshade anchors. Refer to Sunshade Anchor Replacement (See: Sun Visor\Service and Repair\Removal and Replacement\Sunshade Anchor Replacement)
    4. Disconnect the electric connector (2) to the rear view mirror.
    5. Remove the dome light, if equipped.
    6. Remove the assist handle. Refer to Assist Handle Replacement - Rear (See: Passenger Assist Handle\Service and Repair) .
    7. Remove the windshield pillar garnish molding. Refer to Garnish Molding Replacement - Windshield Pillar (See: Trim Panel\Service and Repair\Garnish Molding Replacement - Windshield Pillar) .
    8. Remove the sail trim panels. Refer to Sail Panel Replacement (See: Trim Panel\Service and Repair\Sail Panel Replacement) .
    9. Pull down the door opening weatherstrip seal on both the front and the rear doors.
    10. If the vehicle is equipped with a sunroof, remove the finish lace from the sunroof opening. Refer to Sunroof Finishing Lace Replacement (See: Roof and Associated Components\Sunroof / Moonroof\Sunroof / Moonroof Interior Trim Panel\Service and Repair) in Roof.
    11. Using J 38778 remove the push-in retainers, located over the rear seat, from the headliner
    1. If equipped with a roof rail airbag, disconnect the headliner electric harness (1) from the right airbag inflator strap (2).
    2. Remove the rear window trim panel as necessary to access the headliner harness connectors. Refer to Trim Panel Replacement - Rear Window Shelf (See: Trim Panel\Service and Repair\Trim Panel Replacement - Rear Window Shelf) .
    3. Disconnect the headliner electric harness connectors, located under the right side of the rear window shelf.
    4. Rotate the right front seat back to a horizontal position.
    5. Remove the headliner from the vehicle through the right rear door.
    6. Remove the overhead console, if equipped. Refer to Console Replacement - Overhead
  12. #12 Re: Leaking roof
    atlanta
    Gotta remove the headliner there is a tech bulletin drain plugs back up and leak the water runs down the headliner and pools up by map light making it look lit leak is there. bottom of drain plug should be cut in v shape to help remedy problem
  1. tranny leaking.....
    By badgtp2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2008, 03:38 PM
  2. sunroof/moon roof problem
    By TMOTA503 in forum General Tech Discussion
    Last Post: 03-12-2008, 10:00 PM
  3. Roof rails
    By JashGTP in forum Visual/Body Modifications
    Last Post: 01-13-2008, 03:15 AM
