Thread: Fuel pump not priming HELP!
Results 1 to 5 of 5
  1. #1 Fuel pump not priming HELP!
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    So I was driving to work the other day, and my car died on me a couple times. After that I got done the road and it died again. I immediately noticed that the fuel pump wasn't priming/priming very weak. I was dreading the fact that it is the fuel pump it self and starting doing research. I had a reman MAF and wanted to replace it anyways so I started there since that was a problem I have had before with this car, and still no fuel pump. I also set pin 85 as well. So as I go down the list, what should I consider next? CPS the actually pump itself? Also if that is the case is there an easier way to remove the pump minus dropping the tank? Thanks in advance.
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  2. #2 Re: Fuel pump not priming HELP!
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    The Tank does not need removed. I think only 1997 the 1st half years didnt have the Access hole. Yours being a 2000 has the hole right behind the rear seat under the carpet in the trunk. Takes 10 min to change the pump
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  3. #3 Re: Fuel pump not priming HELP!
    Nov 2009
    Portage, IN
    Yea I got the pump idk I have to find a way to check the point
  4. #4 Re: Fuel pump not priming HELP!
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    did you make sure it was weak by checking the fuel pressure
  5. #5 Re: Fuel pump not priming HELP!
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    jump your fuel pump from a 12v source. if the pump primes, it could be a bad ground/something electrical. if it doesn't prime, replace it.
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
  3. l32 vs l26 fuel pump
    By rodman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 08:15 PM
  4. fuel pump or FPR? or both?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2008, 03:43 PM
