ok so far ive replaced the starter,alternator, battery. and the car wont charge? wtf is going on with my car im about ready to sell it,
I dont know, I replaced the starter because all I was geting was a click at the starter. I would have to turn the key a few times before it started. so the new starter didnt help the problem, then I go to take it to the shop because im fed up at this point and the battery light pops on and I lose all power. so I put a new alternator on it and It didnt help so I try a new battery and my car gave me a big F you.
your gonna have to use a voltmeter to check if theres power going into alternator regulator. and see how many volts are coming out of it and also the wire that goes to the s terminal on the starter. My best guess would be something loose in fuse block, fuse, or ignition switch. have you checked all fuses too see if their good and see if there is current too.
