Thread: HELP car not charging
Results 1 to 4 of 4
  1. #1 HELP car not charging
    Akron Ohio
    ok so far ive replaced the starter,alternator, battery. and the car wont charge? wtf is going on with my car im about ready to sell it,
  2. #2 Re: HELP car not charging
    Jul 2008
    sumter,south carolina
    bad ground?
    02 GTP with mods 05 GP for DD
  3. #3 Re: HELP car not charging
    Akron Ohio
    bad ground?
    I dont know, I replaced the starter because all I was geting was a click at the starter. I would have to turn the key a few times before it started. so the new starter didnt help the problem, then I go to take it to the shop because im fed up at this point and the battery light pops on and I lose all power. so I put a new alternator on it and It didnt help so I try a new battery and my car gave me a big F you.
  4. #4 Re: HELP car not charging
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    your gonna have to use a voltmeter to check if theres power going into alternator regulator. and see how many volts are coming out of it and also the wire that goes to the s terminal on the starter. My best guess would be something loose in fuse block, fuse, or ignition switch. have you checked all fuses too see if their good and see if there is current too.
  1. Question about charging the A/C (97 GT)
    By tesmith66 in forum General Tech Discussion
    Last Post: 04-28-2010, 10:26 AM
  2. Charging system failure
    By Durk Diggler in forum The Rant Forum
    Last Post: 01-10-2010, 05:22 PM
  3. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
  4. battery charging
    By grand2000prixgtp in forum Off Topic Discussion
    Last Post: 09-18-2009, 03:17 AM
  5. Weird charging problem
    By xerxescct in forum General Tech Discussion
    Last Post: 02-07-2009, 08:14 PM
