98 grand prix gtp. I never had a problem before. i replaced the transmission solenoid and now the key wont turn. the steering wheel is not turned, it is straight and is locked. the steering wheel wont move. the car is in park and can be manually released with the shift lock button next to the shifter. the tranny is in park because both of the wheels spin the opposite way of eachother. the car is up off the ground. the ignition appears to be in the "Off" position because the key slides in and out withought any problems. ive tried mashing on the steering wheel to the left and right side while pushing the shift lever into park and still nothing. even hit the brake a few times. the key will not turn from the off position. Any Ideas?!!! ive tried 2 sets of keys. Steering wheel is locked and ignition is in off position. ive even tried taking it apart and hit all the bypass switches underneath the steering wheel.
