Thread: Where is my power steering resevoir?
Results 1 to 17 of 17
  1. #1 Where is my power steering resevoir?
    SE Level Member i3abydoll's Avatar
    Jan 2009
    Delaware
    This could possibly be the dumbest post ever, but I can't find my power steering resevoir! I've had two mechanics look under my hood and we've indentified all the others but that one. I own a Grand Prix 2005 3.7L. Thanks everyone...
  2. #2 Re: Where is my power steering resevoir?
    SE Level Member Hawkeye1975's Avatar
    nj
    on 97-03's its hidden under the alternator.
  3. #3 Re: Where is my power steering resevoir?
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  4. #4 Re: Where is my power steering resevoir?
    Never Never Land
    Ya what he said down under the alternator.
    I didn't realize it was even there till I changed my water pump and had to take off the power steering pump to get to one of the bolts for the water pump.
  5. #5 Re: Where is my power steering resevoir?
    North Carolina
    Quote Originally Posted by 4THGENCAMAROFAN View Post
    Basically what hes trying to say is it's in a terrible spot.
    you'll need a long funnel and some patience to deal with that bad boy
  6. #6 Re: Where is my power steering resevoir?
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    Quote Originally Posted by i3abydoll View Post
    well, it's in contention.
  7. #7 Re: Where is my power steering resevoir?
    If your mechanics can't tell you were the power steering pump is at...I think you need new mechanics.
  8. #8 Re: Where is my power steering resevoir?
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    definitely X2 on that
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  9. #9 Re: Where is my power steering resevoir?
    Charles City, IA
    They are not mechanics if they cant find the p/s pump on a 3.8
    SMGPFC Two Nipple General
  10. #10 Re: Where is my power steering resevoir?
    but he has a 3.7L
  11. #11 Re: Where is my power steering resevoir?
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    ya when i first got my car and saw it was way down there i had to go out and buy a long funnel
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  12. #12 Re: Where is my power steering resevoir?
    buy a small bottle, put it down there and pour.
    very easy, but then again, i dont have a single bracket on my heads cept for the dipstick.
    And yes, i did keep the engine pull brackets/bolts.
  13. #13 Re: Where is my power steering resevoir?
    Jan 2009
    Delaware
    ::sigh:: thanks everyone! One of my goals tomorrow is to get under my hood and do some searchin. I might be a girl, but that don't keep me from gettin dirty! If that fails, I'll prolly just go down the street with a low cut shirt on, and ask for help from the local parts store. It's worked before!
  14. #14 Re: Where is my power steering resevoir?
    I like the low cut shirt idea, lol.
  15. #15 Re: Where is my power steering resevoir?
    Jan 2009
    Delaware
    That's how I got my rear turn signal changed on my Mustang!
  16. #16 Re: Where is my power steering resevoir?
    If you got it flaunt it.
  17. #17 Re: Where is my power steering resevoir?
    Charles City, IA
    Some one needs to go to a junk yard and get a filler neck and dip stick from a 4.3l blazer p/s pmp and see if it works in ours. Might have to bend it a bit.
  1. power steering. feels like i have "half" the power
    By colindunn in forum General Tech Discussion
    Last Post: 07-23-2011, 09:15 AM
  2. power steering
    By thelost1123 in forum Engine
    Last Post: 06-07-2009, 10:47 PM
  3. power steering
    Last Post: 04-11-2009, 10:52 PM
  4. ABS, TC, and Power Steering off...:(
    By nikhackgt2 in forum Brakes/Suspension/Chassis
    Last Post: 02-19-2009, 12:09 PM
  5. Power Steering
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2008, 05:01 PM
