Thread: Vs cam a good Turbo Cam?
Results 1 to 3 of 3
  1. #1 Vs cam a good Turbo Cam?
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    So I'm planning on going turbo over the winter and coming back this spring with a mean a$$ build. I'm going with the z7 kit and an A2A IC.
    Anyhow, my question is How would a vs cam work with that type of build?
    I've noticed that the lift and overlap of this cam is similar to some of the Ideal turbo cams. Also I know that the vs cam bleeds of much less boost than most other cams, and it also performs well with an intercooler.
    And best of all the thing makes a laod of low- mid rpm tourque. being one of the smallest cams for my gtp, and also one of the easiest on the valvetrain, the vs cam is starting to look like it may be a keeper for the turbo build.
    Anyone with a good amount of cam or turbo knowlege please chime in. Anyone ever seen an l67 run this cam with a turbo?
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  2. #2 Re: Vs cam a good Turbo Cam?
    yes, itd make a good turbo cam. turbos like small, smooth cams without a ton of lift.
  3. #3 Re: Vs cam a good Turbo Cam?
    Nov 2009
    Michigan
    Well then. Looks like a winner
  1. HID's worth it? Hi/low/fog necessary? Good brands, with good prices?
    By chamilton89 in forum Audio, Security & Visual Electronics
    Last Post: 08-06-2012, 09:10 PM
  2. no turbo please
    By CHAMPS97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 06:16 PM
  3. Replies: 10
    Last Post: 08-10-2009, 01:54 AM
