So I'm planning on going turbo over the winter and coming back this spring with a mean a$$ build. I'm going with the z7 kit and an A2A IC.
Anyhow, my question is How would a vs cam work with that type of build?
I've noticed that the lift and overlap of this cam is similar to some of the Ideal turbo cams. Also I know that the vs cam bleeds of much less boost than most other cams, and it also performs well with an intercooler.
And best of all the thing makes a laod of low- mid rpm tourque. being one of the smallest cams for my gtp, and also one of the easiest on the valvetrain, the vs cam is starting to look like it may be a keeper for the turbo build.
Anyone with a good amount of cam or turbo knowlege please chime in. Anyone ever seen an l67 run this cam with a turbo?![]()
