Thread: Swap 3.8 (L67) into 3.1 engine compartment?
Results 1 to 4 of 4
  1. #1 Swap 3.8 (L67) into 3.1 engine compartment?
    SE Level Member jerricho's Avatar
    May 2008
    Just curious.
  2. #2 Re: Swap 3.8 (L67) into 3.1 engine compartment?
    Moore, Oklahoma
    It can be done, its been done on many makes and models of car. It just depends if you have the time, money, and know how. Plus some wiring experiance too, extensive depending on what your putting it in.
    Be more specific, like what are you working on? You'll get better answer that way.
    Not being a hardass, we want to help you, we just need more info. No hard feelings...
    Shawn W. Larsen
  3. #3 Re: Swap 3.8 (L67) into 3.1 engine compartment?
    May 2008
    Basically pull the engine from a 2000 Grand Prix GTP which has a bad body and tranny issues and place it in a 2000 Grand Prix SE.
  4. #4 Re: Swap 3.8 (L67) into 3.1 engine compartment?
    Donating Users chico's Avatar
    I know that Rook did this swap ,try PMing him he's on this site occasionally or go over to Grandprix.net and find him.
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  1. 1997 Monte Engine Swap (3.1 3100 V6)
    By StreetChariot in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-25-2008, 08:06 AM
  2. top swap
    By Grandprixboy1224 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-08-2008, 04:23 PM
  3. Need For Gen V swap ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-12-2008, 04:20 AM
  4. 97.5 pcm to 98 swap?
    By monte0 in forum PCM Tuning
    Last Post: 01-07-2008, 10:09 AM
