Thread: DIY Air Intake
Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
  1. #41 Re: DIY Air Intake
    Long Island, NY
    ctkgp what size air filter do you have on your pontiac so i can estimate what size i want based off your pic because i have a gt too.
  2. #42 Re: DIY Air Intake
    Willoughby, Ohio
    4 inches in diameter and 7 inches long
    it fits nicely with a lot of room so you could go bigger if you like
  3. #43 Re: DIY Air Intake
    Jan 2015
    visalia ca
    hi, thanks for this great diy. im gna do this on the weekend, but i need some help. first can i use 4'' piping or is 3'' only option?
    and also what size roof flashing do i need? i know that there are some alumium ones that come with a lock tab fiture?? any advice will be appreciated. thanks i forgot to add that im planninig in using the same method of squeezing pvc in stock rubber hose.
  4. #44 Re: DIY Air Intake
    its called a street elbow. one side is 3 inches. the fatter side that would take another pipe inside it is 4 inches on the out side. cone filter fits right on it. if you are going to a pipe then you need a filter that will fit a 3 inch pipe. spectra filters fit a 4 inch, but have a ring to reduce it to 3 inches.
    the roof flashing you'll want a 3 inch boot to fit the pvc pipe.
  5. #45 Re: DIY Air Intake
    Jan 2015
    visalia ca
    Thanks for the help. i will be trying this out soon.
  6. #46 Re: DIY Air Intake
    Jan 2015
    visalia ca
    Quote Originally Posted by CTKGP09 View Post
    will 10.5 work? i found one on amazon for 40bucks. its a eldelbrock cone filter
  7. #47 Re: DIY Air Intake
    This is a far better deal. You can make it work pretty easy.
    http://www.ebay.com/itm/New-AEM-Wash...#ht_2846wt_786
    AEM filters are the bomb, been running a 4x9 since like 2011. They sometimes have crazy deals on ebay where they are like 70% off, snagged a few for 20 each one time.
  8. #48 Re: DIY Air Intake
    Sep 2019
    Florida
    What size roof flashing did you use?
    1999 GTP. Daily Driver. Just getting Started
  9. #49 Re: DIY Air Intake
    best to buy one that got size rings that you can trim to size. home depot has em, lowes.
    if using pvc pipe thats normally like 3 or 4 inch and they sell the flashing in those sizes as well. 12946 - Oatey 12946 - 3" No-Caulk Roof Flashing (Aluminum)
  1. 4'' intake on an 04?
    By gpgt04 in forum 04+ Specifics
    Last Post: 11-14-2009, 04:15 PM
  2. 3.1L Intake
    By josemolina2008 in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-26-2009, 02:32 PM
  3. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  4. Intake
    By bct717 in forum 04+ Specifics
    Last Post: 03-22-2009, 09:41 PM
