Thread: Need some electrical help
Results 1 to 6 of 6
  1. #1 Need some electrical help
    Jan 2009
    Utica Missouri
    After doing my motor swap my car does not like to come out of park while pressing the brake. i have to press brake and use something to press the bypass button down so i can put it in gear.
    Problem number two
    My abs and track light are on and a pedal is squishy (im going to guess needing bleed some more. (some times my break light flashes)
    problem number three
    When driving down the road. if i put my car in N the HUD, and speedo drop to 0mph, Even if im going 35mph.
  2. #2 Re: Need some eltrical help
    Topeka, KS
    Anthony,
    Spell check your Title man.... and check your ABS wheel sensors for problem #2.
    Problem #3 don't put it into Neutral while driving. (Problem solved )
  3. #3 Re: Need some electrical help
    Jan 2009
    Utica Missouri
    wow, lol thanks. i have been up all night trying to find out why my car would not start (ICM went out of it) i replaced it, and its now running. Ugh need sleep.
    I think problem number 3 and 1 might be related.
  4. #4 Re: Need some electrical help
    Topeka, KS
    Wow that stinks man. Go get some sleep.
  5. #5 Re: Need some electrical help
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    problem number one happened to my car as well i just zip tied the button down so now i can press the brake and shift out of park. when i bought my car the guy told me hesomebody tried to break into it
  6. #6 Re: Need some electrical help
    Jan 2009
    Utica Missouri
    Id rather find the problem and fix it then Band aid it. Your solution works, But can knock it out of gear and into Reverse Very easy. For now id rather put something in the button to move the car.
