i replaced the cooling fan relays and the fans still dont work and the light keeps coming back on.. i had to run a switch and wire so my engine doesnt get hot and my inspection is do this month.. any help?
the control circuit is pretty complicated. i had a problem with the gf's 01 monte. ended up being one fan was bad. but you said both fans work?
both fans work but i only have 1 fan hooked up to the switch
